Air in transmission fluid when changing fluid
Old Apr 8, 2015 | 07:13 AM
BYS2's Avatar
My Ride: 2006 BMW 540i M-Sport
Default Air in transmission fluid when changing fluid
Hi all,
Just have a quick question. I am doing a transmission fluid change and my fluid transfer pump broke so I had to use a large syringe with a plastic tube to fill the transmission fluid.
Now the issue is that I noticed that sometimes the syringe would aspirate a bit of air when I filled it . Of course when I transferred the fluid to the transmission this air would then also be injected inside. I wasn't too worried initially as I assumed the air bubbles will just escape the fluid (like how air bubbles escapes from a glass of water) but I'd rather be sure. So does anyone know if there is any cause for concern about this?
Thanks!
Old Apr 8, 2015 | 01:45 PM
pcy's Avatar
pcy
That shouldn't be a problem.
Did you make sure correct amount of fluid is in the trans? Fill process requires the trans be within a specified temp range. Did you follow that procedure?
Old Apr 8, 2015 | 03:29 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
Those air bubbles will work their way out of the fluid during normal use. The transmission case is vented at the top, so any excess air/pressure has a way to escape.
Old Apr 8, 2015 | 06:16 PM
BYS2's Avatar
Great! looks like I don't have to start over then. Thanks!
I followed the procedure as best as I can. The fluid did overheat to >50 degrees at some point and I stopped filling and left it overnight to cool down before starting again. Very messy and long job as I only had car jacks (no lift) and had to use syringe to transfer fluid. Hopefully, it all works out!
pcy
Sep 12, 2021 06:55 PM
dsummersm3
Nov 14, 2019 07:50 AM
cinergi
Aug 3, 2018 04:31 PM
kongse
Jul 17, 2015 03:29 PM
ashamlawi
May 8, 2015 06:50 AM
