Air flow meter location - N63 550i
My Ride: 2004 BMW 545i, M-Sport Bodykit, Sports Suspension, Sports Seats, Active Steering.
I am having issues with misfiring and plugs have carbon soot on them which seems to indicate running rich in fuel, air filter may need replacement and I will also attempt to clean air flow meter.
Does anyone have a photo which shows where the air flow meter is located in the engine of the N63 550i? Is there much work involved to remove it?
My Ride: 2010 550i ZSP
Model Year: 2010
Engine: N62
If you mean the Mass Air Flow (MAF) sensor, it's in the duct that connects from the air filter box to the engine, which runs right across the front, top side of the motor. When you open the hood, it's the first plastic duct you see right in front of you. Very easy to get to and remove/replace.
dvs0690
Mar 21, 2018 05:13 AM
EuroCarFan
Apr 5, 2011 08:13 PM
