Aiming Headlights?
Engine: N54
I recommend you try taking a picture of your headlight pattern against a wall or garage door to confirm before you look for the instructions about making any adjustments.
There are two white dials w/ hexagonal insert on top of the left and right headlights. The outer one controls the left/right aiming. The inner one controls up/down aiming. You can adjust it however you like, just be careful not to blind oncoming traffic - xenons are crazy bright.
I just recently found out that the BMW screwdriver in the trunk tool box fits perfectly into the adjustment dials.
My Ride: E60
This is normal over time from hitting bumps and normal driving the headlights need to be adjusted. I adjusted my after lowering my car. Open the hood at night against a closed garage. Turn on your lights and grab a 6 corner screw driver end tip. There are holes on both sides on top of the headlights to turn and adjust. Pretty simple once you do it.
![](https://5series.net/forums/public/style_emoticons/default/thumbsup.gif)
My Ride: BMW
Yeah it's normal for the driver side headlight to be lower than the passenger side.
Adjusting_headlights.pdf
I just figured it out. I don't think I have a left and right adjustment because my headlights are adaptive. I moved it up with the white allen type screw in the picture.
Vman33
03-14-2022 04:43 AM
umnitza
11-25-2015 11:10 AM
Bogdan7
09-23-2015 11:40 AM
