Aftermarket Sound system help
My Ride: 2003 545 se
I recently installed 2 subs an 2 6x9s powered by an aftermarket amp that takes speaker level input from the underfloor subs. Everything seems to work fine but when I turn the volume up the audio signal cuts out an wont come back till it switch the ignition off an on. The amp stays on so I think the problem is the head unit since all audio stops including the stock speakers that are not powered by the aftermarket amp, It defiantly seems volume dependant as I can lesson at moderate volume without any issues.
Is there any way to test if the M-ask is overheating?
What else could cause all audio to stop while the I drive continues to work?
Thanks
Thanks
I had a look this morning an the code is 9AFF SFZ: Resistance, firing circuit, safety battery terminal, too high . I tested with the IBS lead disconnected an it seemed to solve the problem, it played for longer an didn't cut out. I looked at the temperature for the M-ask Most loop an with IBS lead connected the audio stopped after a about two mins stock amp temperature was 48 C, without IBS connected I played for over 5 mins at full volume an temp stayed around 50 C. Not sure if this is a fix or not yet...
Do you know what temperature is normal for the stock amp in the head unit?
Is there any other temps I can read other than those found under Communication /Mask Most network /Status in INPA?
Thanks
Thanks
subterFUSE
03-28-2013 09:28 AM
haugejan
04-15-2010 11:09 AM
kdarcia007
10-13-2009 02:23 PM
