Active Steering faulty
Old Jun 21, 2006 | 10:35 PM
MRF550i's Avatar
My Ride: 2006 Black Saphire Metallic 550i, tan leather, nav, heads up, comfort seats, front heated seats, premium sound, logic 7, comfort access.
HELP PLEASE.
This morning when i was pulling out of my garage, i got this message saying that "Active Steering Faulty"
I restarted the car a few times and the message would not dissapear.
Has anyone gotten this message before and if so how can i fix the fault???
BTW the car is brand new with 600Km on it
Thanks,
Old Jun 22, 2006 | 06:27 AM
EBMCS03's Avatar
http://forums.e60.net/index.php?showtopic=27547
Old Jun 22, 2006 | 06:57 AM
Fireplace's Avatar
Originally Posted by MRF550i' post='301284' date='Jun 22 2006, 02:35 PM
HELP PLEASE.
Thanks,
I had the same problem with my new car and it was diagnosed as computer glitch. Dealer reset the software and everything back to normal.
One way to tell is if the active steering still function normally, meaning no change in steering behavior, it is most likely a false alarm. I am pretty sure it's not a major problem. All the best.
Old Jun 22, 2006 | 07:17 AM
markt540i's Avatar
My Ride: 2010 750Li M sport
Mine started this about ten days ago. I have an appointment tomorrow to take mine in. The active steering definitely stops working with the steering going to an apparent fixed ratio...having to turn more than normal at slow speed. The feel is still the same. Sometimes, like if I have my wheel turned when the warning comes on, the wheel will line up wrong. In other words, while driving straight the wheel is turned toward say 10 o'clock.
I do miss active steering when it is not working.
Old Jun 22, 2006 | 07:22 AM
JDN's Avatar
JDN
I've had several fault messages, but none in active steering. None of the fault messages has ever proven to be a true fault. Some are slower to go away than others. I used to get that DSC fault a lot with the topsy vehicle in HUD for absolutlely no apparent reason (usually driving like and old man when it occurred ). It always corrected itself and dealer could not find anything when I finally showed up for service. Gas cap was another that was slow to cure itself, but finally did.
Old Jun 22, 2006 | 07:37 AM
MRF550i's Avatar
I called the service center today and they said that the software need to be reset. They said that there is an update that need to be loaded for about 3 hours and the problem will go away.
By the way the active steering is not working, i can feel it when i drive.
I'll update you guys once i finish the reset.
akaveli3
Jan 12, 2021 08:46 AM
teerapote
Aug 26, 2015 05:24 AM
cjpearson89
Aug 5, 2015 02:52 AM
teerapote
Jul 29, 2015 11:50 AM
ST JAMES
Jul 3, 2015 07:04 PM
