Acceleration hesitation issue
Old 10-02-2017, 05:31 AM
  #21
Razzy530's Avatar
My Ride: 2007 E60 530i 6 Speed Silver Gray
Engine: N52
Today is the day I will install the coils. Will update you guys in the next couple of days of driving.
Old 10-03-2017, 07:41 AM
  #22
Razzy530's Avatar
Engine: N52
******UPDATE*****
The misfire is due to oil leaking through the spark plugs and mixing with electricity. What i need now is a valve cover gasket job along with plug seals and the eccentric shaft sensor replaced. $$$
Coils are fine.
Old 10-03-2017, 10:33 AM
  #23
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
That should be fun. It's not too expensive. Buy the parts and spend a Saturday doing it yourself.
Old 10-04-2017, 05:17 AM
  #24
Razzy530's Avatar
Engine: N52
The Sensor alone is $560. The gaskets are $100. But i dont have the capacity to handle that so its costing me $1200 at the dealer
Old 10-04-2017, 12:57 PM
  #25
Model Year: 05 530i
Engine: 3.0 M54
The sensor is $260 at most and the gasket is no more than $35. If you are buying it at those prices then you're getting robbed. Check out pelican parts. I'm sure the VDO sensor which came in the car from factory is not near $500. And if you shop around you might can find the VDO at $200. If you are getting those prices from the stealership invoice then I see why they are so expensive. I would suggest an Indy for this job. A 10 year old car at the miles you have are not worth waisting money at the dealership. That is just my opinion.
Old 10-05-2017, 08:14 AM
  #26
Razzy530's Avatar
Engine: N52
End result. No more bucking and misfiring. Car is running well so far. Still on original ignition coils. Those i can do myself if i ever get a fault or whatever. Hope this helps to anyone with this issue. Oil and electricity dont mix. hehe.
Old 10-07-2017, 07:33 AM
  #27
Razzy530's Avatar
Engine: N52
The price of 1200 at the "stealer" was 200 less than the Indy was quoting me. FYI
Old 10-17-2017, 11:56 AM
  #28
buddy's Avatar
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, staggered 19 inch BBS rxII/michelins, H&R coilovers and intergrated, R1 concept drilled an
Engine: 530i
I replaced my valve cover gaskets awhile ago never rechecked the plugs but i did when i replaced coils maybe time to recheck those plugs again
Old 10-17-2017, 02:45 PM
  #29
Razzy530's Avatar
Engine: N52
just pull the coils out to see if they're all dry. Mine weren't. Cylinders 3 and 4 were soaked in engine oil. Therefore misfiring every so often. I definitely feel the power back too. And im still on the original coil pack. Will replace those as needed.
Old 10-07-2019, 04:38 PM
  #30
Alex Costa's Avatar
My Ride: E46 330
Default Responding to this post late, hope it's helpful
Originally Posted by Razzy530
i figured that. Maybe its time
I came to this looking to help fix my 2010 535i. I experienced this same issue with my 2001 E46 330xi and did replace my ignition coils but that didn't fix the RPM fluctuation. Do replace your DISA Valve, the seals fail on it and my problem was fixed.
Good luck!
2001 E46 222k Miles in Northeast USA
hc115
05-12-2015 06:37 PM
buddy
05-07-2015 03:35 AM
Steve J
04-17-2015 08:10 PM
BILLYBOB
05-14-2004 12:47 AM
Quick Reply: Acceleration hesitation issue
