AC Problem, Please help
My Ride: e60
Hello,
So my ac doesn't work anymore. My heater works but only on the bottom and top and rear vents. The center vents do not work at all. Before I start splurging on more items I would like to gain some insight. Please, HELP. Its so hot in the bay area and would like to get this fix asap. So far ive replaced the blower motor and the resistor. I'm receiving the climate control unit today so hopefully that might be the problem since its such a easy fix. Or could it be heater valve control? I've spent in total of 600 dollars already getting it diagnosed and on parts mentioned above. Its sucking me dry again please help
Here are the codes its throwing off:
009C5C IKHA: Evaporator temperature sensor
009C60 IKHA: Heat exchanger for heating system, sensor, right
009C67 IKHA: Heat exchanger for heating system, sensor left
00E706 IKHA: Heater-AC systems LIN bus fault
0099C55 IKHA: Fogging Sensor
S0072 No communication with control centre/control panel
My Ride: 2007 BMW 550i
I've read a fault fog sensor can cause these issues, somebody with NCSExpert can disable it, but that wont solve the codes for all the other issues your having.
My Ride: Yes
My Ride: e60
so I figured out what my problem was. It was actually just the climate control unit. so I'm assuming the butt connector or the buttons were faulty but I replaced that and t works now! bought one off eBay for like 80$. good luck on your ac man!
bmwmonkey
08-17-2015 10:34 AM
2000avant
03-22-2004 08:57 PM
