(ABS) Braking / Driving Stability Message
Dear Members, i have recently start receiving this message((ABS) Braking / Driving Stability Message, get your break checked) and the worrying thing is i get this message some time when i press the driver & passenger window button together and in the mean time music cuts off for a second and then everything goes back to normal, this only happens some time, all your help will be appreciated, just to let you know breaks on my car are fine as i only got them checked last week, thank you
Usually this warning light combination comes on due to a malfunctioning wheel speed sensor. Although how you explain your situation I'm not sure if that is the case, seems a little odd. Anyway it seems like one of your sensors is going poopy.
In the absence of any other symptoms, I'd say, one of the wheel speed sensor is acting up.
Worst case scenario, the ABS pump or the control module is the culprit.
My Ride: BMW
Even affecting the radio???
Was the car in heavy rain lately? I guess in Dublin it's possible, but depending on the year of your car, check the spare tire area and see if your microprocessor module is still there and not swimming in collected rain water.
Thank you for ur replies, ya its effect the car radio, mean i use fm transmitter. car battery is fine, i have not seen any trouble , but i will check the unit under the spare tyre but in the mean time is there anyway to check which wheel speed sensor is faulty? thank you
Awest91
09-17-2022 11:05 PM
TexaZ3
05-06-2015 09:54 AM
