ABS-Braking-Driving Stability Issue
My Ride: I have a 2007 Black Sapphire BMW 530i with SMG. It has the auburn interior, has PDC, Sports Package, Premium Package, rear automatic sunshades with manual side sunshades, 35% black tint, Upgraded angeleyes from Angelibrights, and Logic 7 Sound System
I have a 2007 530i SMG. I recently replaced the brakes and rotors about 2 months ago. For the past 2 weeks, I have been noticing an increasing softness in the pedal. When I press in, it feels like it is not stopping and I have to push down kind of far. Anyways, today I was driving and I could feel the car getting slower. At first, I though it was a flat tire but I checked and all the tires were fine. Then I noticed that it was the front brakes. It seems as if they are stuck. I was driving at about 30-45 range. I got to the light and the ABS sign came on and the drive slowly sign came on. I attached the pictures. Before I have it towed somewhere, here are the possible things I am thinking:
a) Low brake fluid
b) Incorrect bleeding of brakes upon installation
c) Stuck Break? Thats what it seems like.
d) The parking brake
Thanks for the help everybody!
a) Low brake fluid
I cant see the photos they're too small. I think you may have air in your system. Check your resevoir to see if it's now. If you just replaced pads and rotors you shouldnt be having this issue unless whoever did the job popped a hole in or ripped the caliper and fluid is leaking out and air is getting in. You should have a sealed system. The DSC unit is tied to ABS as well. But chances are that you didn't have anything done so check the resevoir and see if you're low. If you're low, then you have a problem (leak)
Why did you decide to replace the pads/rotors? was it that time or are you having some sort of issue that you thought that pads/rotors would take care of?
Yea it was time. My problem is that I am not sure that they bled the brakes properly when replacing the parts. Hopefully I figure it out today. Anyway for me to get the car moving? The front brakes just seem locked on. I don't want to have to get it towed.
Everytime I try to accelerate, I feel like the car is bogged down. And now I think its the front brakes so wish me luck, hopefully I can figure this out without having to tow it to a mechanic. Ill take better pictures in a bit once the coffee kicks in lol.
Model Year: 2015
Engine: N55
Replacing pads and rotors should not require brake bleeding.
Im leaning towards the battery being bad and causing the DSC to act up causing the ABS to malfunction and lock up the front brakes.
Or I could be totally wrong lol
All the signs are gone now...so Im going to replace the battery today I guess with Duralast Gold 95R-DLG. Hopefully it works.
Update: Brake Fluid is at optimal level...going to try the battery tomorrow but as of now, the car drives fine.
Good deal. Get an H8 battery as it's the same as the OE battery. Q: Did you tell the person to bleed your brakes? If so, then he may have done it and incorrectly. If it was the battery I am sure you'll get more than a simple ABS error. If you asked to have brakes bled he probably let air in the system which will throw this light. The system needs to be completely sealed and air free.
