8.8" screen in buisness nav
Is it possible to retrofit just the bigger screen on buisness nav? The bigger screen looks much better.
BTW on pro nav, do you have to use the split screen? Can you just use the entire screen for 1 thing like the navigation or climate?
My Ride: F02 LCI Individual
Model Year: 2013
[snapback]48306[/snapback]
But on pro nav you HAVE to use the split screen all the time. Only the main menu is using the entire screen.
My Ride: G30 M550i
Model Year: 2018
I'm going to bet that if you install the bigger screen, the only thing you'll see working is the first 2/3rds of the screen. I doubt that the car will automatically use the wider screen without having the pro nav computer and accompanying software.
Model Year: 2013
Originally Posted by Rudy' date='Oct 23 2004, 09:49 PM
I'm going to bet that if you install the bigger screen, the only thing you'll see working is the first 2/3rds of the screen.? I doubt that the car will automatically use the wider screen without having the pro nav computer and accompanying software.
[snapback]48440[/snapback]
jcolley
08-01-2016 06:48 AM
Bank$hot530
09-16-2015 01:28 PM
