6spd Manual Owners a little help please..
It recently started when i felt the gearstick vibrating (or pulsating more accurately) while on the highway. After abit of experimeting i can see the following
a)The vibration is more evident in neutral, 2nd and 4
b) It's gets the strongest on 2250rpm and 2750rpm
c) It reduces past 3K and higher
d) It gets worse if accelerate, if i let the gas off it subsides.
e) After 2 minutes of holding the gearstick (not pressing, from the sides) my hand got num
f) On neutral, i can even feel the vibration through the seat and on my back
Stated all that to the dealer and he said cannot see anything..
I say bull ...
I'm changing dealer now. Any ideas to what might be wrong ? That way i'll have to say something to them ..
Thanks for the help
I say bull ...
Thanks for the help
Now thats a tough one!! it cant be any of your drive train as its doing it in Neutral, so that eliminates wheel bearings, drive shaft, diff etc, have you lifted the bonnet whilst in neutral with the engine running, ive a feeling its is a bottom engine mount, take a look and let me know bud!!
Hmm, that's not a bad idea, at all.. Not wheel bearings for sure , the car is stationary on neutral (as you probably imagined).
I'll take a look, definately!
By the way, didn't you have a different avatar ?
Yep different avatar, i usually change them every couple of days or weeks, its just something i do to keep myself entertained
Engine mounts would transfer vibrations not only to the "stick" though... still, a good place to start looking for the root of the problem.
I'd also look at transmission mounts. Could it possibly be ground gears? Just based on what you're saying (vibrates in 2nd and 4th gears and at certain rpms - where the peak torque starts, basically), for some reason I'm thinking gears... but I'm by far not a pro on this - really, I'm just throwing this out there so that someone who knows better can say its definitely not this...
There is one simple fix if you want to try that first. Under the leather gaiter you will see a vibration damper screwed on to the gearshift. Loose the screw and move that upwards. The higher to take it the less vibration you will get but too high and the screw will get in the way of the gaiter. Hope that helps.
Also, it is the strongest in neutral -when i can actually feel the vibration through my back .
Funny enough, today is abit colder and i couldn't get to vibrate for at least 20 min. I've hard revved the engine abit (5k) and then it appeared again.
Still not as evident on any gear as before, BUT as strong as before on neutral.
Either way will have a look on the engine mounts and report back
Originally Posted by spiros' post='924485' date='Jun 26 2009, 04:32 AM
The vibration is more evident on neutral 2nd and 4rth, it's there as well on all of the other gears just stronger on the ones i've said.
Bruce's fix is DEFINITELY worth the shot - it is VERY possible he's got the remedy for your issue.
