6 CD Changer Problem?
My Ride: 530D SE
Every time I unlock and enter the car, the 6 CD changer in the glove box cycles through (loads/unloads) all 6 CDs. It's a bit of a pain
Is this normal?
Thanks.
Ian.
![Getlost](https://5series.net/forums/images/smilies/imported/getlost.gif)
![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
Thanks.
Ian.
My Ride: BMW 550i 2007 M-Kit installed- 367 BHP Sapphire black, comfort seats, comfort access, HUD, Professional Nav, Logic 7.
Is this normal?
Thanks.
Ian.
Thanks.
Ian.
no this is not normal... have it checked!!
My Ride: 2005 545 Silver Gray/ Beige, 6sp Manual, Sport, Nav, Comfort Seats
Is this normal?
Thanks.
Ian.
Thanks.
Ian.
It could also be a problem with the car not going in to "sleep mode", where something is drawing a charge from the battery.
The dealer should be able to diagnose and remedy.
My Ride: 2004 e60 M5 Replica
Titanium Silver
Premium Package
Premium Sound Package
Adaptive Xenon's
Apple iPhone cell interactive pared with iDrive Bluetooth setting
19 inch BMW OEM 166M rims,
Michelin tires
Sprint Booster - V2
Fidelity / BMW Extended Warranty 7 year / 100,000 miles
Is this normal?
Thanks.
Ian.
Thanks.
Ian.
Mine does "loads" in the glovebox changer and makes that annoying sound, but it dont do it always. I have had problems with the six disk icons that you can click on will not lighting up so I can select a CD to play!! I had it back into BMW and they can never get it to fail! What is go out completly after my 4yr/50,000 miles BMW waranty does!!! (LOL)
Eddie Presley
My Ride: .
Model Year: .
Originally Posted by Cooperman' post='573206' date='May 2 2008, 04:22 PM
I had the same thing happen on mine. The problem turned out to be that the battery did not have enough of a charge, so all the peripherals that normally run are shut down.
I am not sure about the battery, i have this same issue and have replaced the battery, both with a OEM one, and now an Interstate battery, i get the same thing, I have nothing aux plugged in no cell charger etc... and yet i get the same thing almost but not every time i get in,
I will check the sleep mode, and i have scheduled to have the i drive updated, but i have also read it is possible my earth ground on the battery is not properly secure, but i have not found which wire that is in there, if anyone can point it out it would be great,
this is the first and only issue i have with my 545i, but i feel the frustration of people that have this problem, it is weird,
I am also having them run a diagnostic on the alternator just incase,
My Ride: 530D SE
At the independant service I had the battery tested out of the car amd an earth leakage test and all is ok. No error codes either. I'm now at a loss what this is. Sometimes after a run and then the car is left for a short while, when re-entering the CD changer cycles again, yet surely the battery must have had a good charge minutes earlier? I'm sure it hasn't always done this so not sure how a software error could have crept in somewhere???
Trying to avoid a main dealer bill if possible
![Blink](https://5series.net/forums/images/smilies/imported/blink.gif)
My Ride: 2008 E61 525DA, Beige bport leather seats, adaptive bixenons, PDC, NAV Pro, Carbon Black, M-Sport, Head-Up.
