550i 6 speed manual can't find replacement driveshaft cv joint
Probation Members
My Ride: 2007 550i 6 speed manual
So I have a 6 speed 2007 550i and my driveshaft cv joint needs replacing. I can not find a cv joint for a manual transmission anywhere not even from bmw. From what I've researched the only difference I can see is the end of the joint that mates with differential is larger on the manual trans vs the auto. So my question is if I can just use that end cap from my old part on the new (automatic) part and theoretically have a functioning replacement? Or is my only option buying a whole new drive shaft/ buying an auto shaft and making a hybrid shaft + auto differential?
Realoem.com is a parts website. Best if you can put in your VIN, but I chose your car and year. Looks like the driveshaft CV joint you need is 26117525812.
08535 (04-28-2022)
dasdas
09-14-2009 08:19 AM
