550 Stuck Muffler Valve
Old 04-24-2007, 09:33 AM
JDN
JDN's Avatar
Bill, there is a spring that holds the flap in the closed position until the RPMs get high enough for the valve to open. Best I can tell from what you have posted, there is nothing wrong with your flap.
Old 04-24-2007, 10:11 AM
JetBlack's Avatar
My Ride: 2007 BMW 550i w/SMG - JetBlack - Dinan Software - Dinan Exhaust - Anthracite Trim - Anthracite Headliner - Sport Package
Old 04-24-2007, 12:08 PM
Biff Trout's Avatar
My Ride: 06 550-6spd
JDN,
Go back to my original post. The operative word is "stuck". There is a distinct difference between held closed by a spring and stuck.
Also, start reading between the lines. When a person says "Had the exhaust system off the car yesterday to perform adjustment to shifter . . . ", it is reasonable to presume that such a person might know a bit or two about cars and perhaps even a thing or two about what constitutes "stuck".
Let's see what people who have experienced the problem have to say.
Old 04-24-2007, 12:41 PM
AlB
AlB's Avatar
Originally Posted by Biff Trout' post='417241' date='Apr 24 2007, 12:09 PM
Had the exhaust system off the car yesterday to perform adjustment to shifter and further examined the valve.
No corrosion, no evident reason for it to have been stuck. Hmm?
Biff,
I am getting ready to install a RE SSK/WSR on my 550i soon. I noticed you had to make an adjustment to the shfter. What kind of issues were you experiencing that required you re-visit the installation?
Sorry for hijacking your thread.
al
Old 04-24-2007, 01:28 PM
Biff Trout's Avatar
Originally Posted by AlB' post='417347' date='Apr 24 2007, 03:41 PM
Biff,
al
Al,
The RE SSK/WSR is great. Had one on my e39 540 also. Adjustment that I made was to put about 5 degrees of forward bend in the shift lever just above the pivot ball. This moved the pattern closer to the dash which is a personal preference issue only and not an issue with the SSK. PM me with any other questions on the SSK/WSR.
Old 04-25-2007, 08:17 AM
JDN
JDN's Avatar
Looks like the field of "experienced" will be small since no such posts into your fourth day on the subject. Goog luck.
Old 04-25-2007, 10:58 AM
diveleader's Avatar
My Ride: 545i SE Oct 03 (53 plate) 19" Alpina Classic rims
I noticed that mine was also 'stiff'. Operating the actuator by hand was very difficult - it also felt like it was rubbing sometimes when manually opening. (like grit was present).
With the level of friction, I don't think that a vacumn actuator could open it - although I can't think of a way to check this.
In the end I strapped mine in the 'open' position - this increases the V8 'rumble' at tickover, which I thought was lacking somewhat (there are other posts on people fixing this actuator into the open position.)
I prefer the addtional tones, but I do think that the torgue has been reduced slightly (at low revs).
However, having the valve held open is probably better then having it stuck shut.
What about a high temp silicone grease?
Old 04-25-2007, 08:38 PM
EBMCS03's Avatar
Someone wiht a new 550 test their valve and tell us how many Newton Meters of Force it took to open it.
Old 04-26-2007, 06:12 PM
Biff Trout's Avatar
Forget the Nm's. When mine was new, it was easily operated with one finger pushing on the lever end of the butterfly pivot shaft. After lube and much exercising, it is now same as new. Question is how long that will last.
PelicanParts.com
Meet & Greet Discussion
10-16-2015 03:07 PM
kcrokin
09-28-2015 08:47 PM
FADAGUY
09-18-2015 09:03 AM
Bank$hot530
09-16-2015 01:28 PM
militantgrunt
09-10-2015 02:31 PM
Quick Reply: 550 Stuck Muffler Valve
