545i still has rough idle - advice needed ASAP!
My Ride: 2004 545iA - Built date 09/03, Sport Package, Alpine White III, Grey Interior, Cold Weather Package, PDC, Rear Electric Sunshades, Comfort Seats, Logic 7, Chromed BMW Style 124 18x8, 18x9 Wheels, M-Tech Aero Kit, Rear Trunk Decklid Spoiler, Tinted Windows, Valentine One
Modifications: RDSport Quad Exhaust, 20x8.5 and 20x11 HRE 943R, Vorsteiner CF Decklid, Dinan CAI
Originally Posted by cobradav' post='324473' date='Aug 19 2006, 05:09 PM
Are u kningly putting ethanol "enhanced" gas in your car or is it unmarked and it "might" be. BMW does have a bulletin out saying they do not recommend more than 10% ethanol
SI B 13 01 06
Fuel System & Control March 2006
Technical Service
SUBJECT
Alcohol Fuel Blends in BMW Vehicles
MODEL
All with gasoline engines
SITUATION
Fuel blends containing a high percentage (above 10%) of alcohol, mainly ethanol, are becoming more commercially available. Customers inquire about the possibility of using alcohol fuels (e.g. E85) in BMW vehicles.
INFORMATION
Fuels containing up to and including 10% of ethanol or other oxygenates with up to 2.8% oxygen by weight, that is, 15% MTBE (methyl tertiary butyl ether) or 3% methanol plus an equivalent amount of co-solvent, will not void the applicable warranties with respect to defects in materials or workmanship.
Although, usage of such alcohol fuel blends may result in drivability, starting, and stalling problems due to reduced volatility and lower energy content of the fuel. Those drivability problems may be especially evident under certain environmental conditions, such as: high or low ambient temperatures and high altitude.
Only specially adapted vehicles (FFV - Flexible Fuel Vehicles) can run on high alcohol fuel blends. BMW, for the various technical and environmental reasons explained below, does not offer FFV models.
Usage of E85, or any other high alcohol content blend (e.g. E30) in BMW vehicles, will cause various drivability complaints (cold start problems, stalling, reduced performance, poor fuel economy, etc.), may cause excessive emissions, and may cause irreversible damage to engine, emission control and fuel delivery systems due to incompatibility of materials with alcohols.
General Notes Regarding E85 Fuel.
E85 fuel contains 85% (by volume) of ethanol and 15% of gasoline. Ethanol can be produced chemically from ethylene or biologically from grains, agricultural wastes, or any organic material containing starch or sugar. In the US, ethanol is mainly produced from corn and is classified as a renewable fuel.
Similar to gasoline, ethanol contains hydrogen and carbon; with additional oxygen molecules build into its chemical chain. This chemical structure makes ethanol's burning process slightly cleaner compared to the gasoline (lower tailpipe emissions).
On the other hand, due to lower carbon content, ethanol provides 27% less energy (for identical volume) then gasoline, resulting in the reduced fuel economy of E85 vehicles (approximately 22% higher consumption). Increased fuel consumption requires the appropriately enlarged fuel tank capacities (usually 30% increase), and the specific DME calibrations for the E85 lower Stoichiometric air/fuel ratio (10 compared to 14.7 for gasoline engines).
E85 fuel volatility is typically lower then gasoline (RVP 6-10 psi, compared to 8-15 psi for gasoline). Lower fuel volatility will reduce vehicle evaporative emissions, but it may cause cold starting problems especially with lower ambient temperatures.
Under certain environmental conditions, mainly lower ambient temperatures, ethanol separates from gasoline/alcohol mixture and absorbs water. The ethanol absorbed water molecules are heavier then gasoline or ethanol, they remain at the bottom of fuel tank and when introduced into combustion process they tend to form an extremely lean mixture resulting in misfire, rough idle and cold starting problems.
Certain materials, commonly used with gasoline are totally incompatible with alcohols. When these materials come in contact with ethanol, they may dissolve in the fuel, which may damage engine components and may result in poor vehicle drivability.
Some metals (e.g. zinc, brass, lead, aluminum) become degraded by long exposure to ethanol fuel blends. Also, some nonmetallic materials used in automotive industry such as: natural rubber, polyurethane, cork gasket material, leather, polyvinyl chloride (PVC), polyamides, methyl-methacrylate plastics, and certain thermo & thermoset plastics degrade when in contact with fuel ethanol.
In order to safely and effectively operate a motor vehicle running on E85, the vehicle must be compatible with alcohol use. Some manufacturers have developed vehicles called FFV (Flexible Fuel Vehicle) that can operate on any blend of ethanol and gasoline (from 0% ethanol and 100% gasoline, up to 85% ethanol and 15% gasoline). Ethanol FFVs are similar to gasoline vehicles, with main differences in materials used in fuel management and delivery systems, and DME control module calibrations. In some cases, also E85 vehicles require special lubricating oils.
Aftermarket conversions of gasoline-powered vehicles to ethanol-fueled vehicles, although possible, are not recommended due to internal materials and DME software incompatibility, as well, as the high costs of conversion.
WARRANTY INFORMATION
Components damage/malfunctions, or any drivability problems caused by use of fuels containing more then 10% ethanol (or other oxygenates with more then 2.8% oxygen by weight) will not be covered under BMW warranties with respect to defects in materials or workmanship.
SI B 13 01 06
Technical Service
SUBJECT
MODEL
SITUATION
INFORMATION
Originally Posted by Hormazd' post='324432' date='Aug 19 2006, 12:29 PM
There is a recall on the 545 for part on the induction system that causes noticeable rough idle. See your dealer.
Originally Posted by EBMCS03' post='324409' date='Aug 19 2006, 11:21 AM
Wow Yikes... still having the problem?
Just a off the wall thought... When or have you added any oil to your engine? When was your last oil change?
Possibly April 06? May 06?
But then again if they tested and adjusted the valve lift would the engine oil need to be drained for that?
I'm just thinking it might have been over filled with oil and thats causing the roughness... again off the wall thought since you dont seem to be having any luck with the dealers...
EBMCS03: I have never touched the oil or had an oil change. Thanks for your thoughts!
Originally Posted by remuse' post='325146' date='Aug 21 2006, 10:14 PM
Cobradav: I just pump 91 Octane at Chevron or Shell normally.
However, the other bulletin discussed in this thread is the intermediate levers here: However, I thought this had been discussed in one of your other threads but may be mistaken.
SI B 11 02 05
Engine January 2006
Technical Service
This Service Information bulletin supersedes S.I. B11 02 05 dated May 2005.
designates changes to this revision
SUBJECT
N62 Engine - Rough Idle, Misfire Faults after Cold Start
MODEL
E53 (X5 4.4 i/4.8is); E60, E63/64, E65/66 with N62 from 06/04 up to 02/05 production
SITUATION
Customer may complain of erratic engine idle speed lasting for approximately 20 seconds after a cold start. Check Engine Soon light may be illuminated and misfire faults for various cylinders (e.g. FC 2742, 2743, 2744, 2745, 2746, 2748, 2749, 274E) may be stored in the DME.
CAUSE
Incorrect tolerances and geometry of Valvetronic intermediate levers are causing uneven cylinder filling during the transitional cold start period (60 seconds after the engine has been started) when the Valvetronic system is switching from the initial 6 mm to a minimum 0.3/0.8 mm valve lift.
CORRECTION
On a customer complaint basis, and after performing diagnostic procedure described below, replace the Valvetronic intermediate levers.
PROCEDURE
Perform basic engine diagnosis (compression, ignition, fuel pressure, etc) to rule out other potential causes.
Allow the engine to cool down.
Connect GT1/DIS loaded with CD 44.0, or higher, to a cold vehicle (coolant temperature below 30 deg C) and from the Function Selection select: "Service Functions", "Drive", "Engine management ME9", "Test runs" and then "Tolerance test, intermediate lever".
Start the engine and follow-up the test plan.
Observe rough running values when idle speed stabilizes. If values are in excess of +/- 2.5 accompanied with noticeable engine vibration (and sometimes Check Engine Soon flashing), then remove valve covers on both banks.
Look for the intermediate lever production date (stamped on the lever, next to the smaller roller contacting the eccentric shaft).
If the production date is in the range between "04 180" and "04 324" (e.g. day 324 of the year 2004), then the whole set of intermediate levers (16) has to be replaced. The same classification of levers must be used when ordering the intermediate levers (classification number is stamped below production date). There are 5 classifications of levers used in the N62 engine.
Note: In an individual cylinder head, all levers must have the same classification, but two different classification of intermediate levers may be used in one engine (e.g. bank 1: classification 2, bank 2: classification 3).
Important: The lower production range of the affected intermediate levers is only an approximation. It is possible that levers produced prior to "04 180" (but not earlier then "03 363") may have certain deviations in tolerances.
For Valvetronic intermediate lever replacement procedure, refer to RA 11 37 012 (bank 1) and RA 11 37 014 (bank 2), found in BMW TIS.
IMPORTANT:
Improved intermediate levers are currently available from our Parts Department.
In the event of a reproducible customer complaint proceed with the diagnostic and repair procedure. There is no need to contact Technical Hotline.
PARTS INFORMATION
Part Number
Description
Quantity
11 37 7 516 895
Intermediate levers class 1
Maximum 16
11 37 7 514 012
Intermediate levers class 2
Maximum 16
11 37 7 514 013
Intermediate levers class 3
Maximum 16
11 37 7 514 014
Intermediate levers class 4
Maximum 16
11 37 7 514 015
Intermediate levers class 5
Maximum 16
11 12 7 513 194
Valve cover gasket bank 1
Valve cover gasket bank 2
Tensioner sealing ring
Valvetronic motor spacer ring
Timing chain cover, u-shape metal gasket, bank 1
Timing chain cover, u-shape metal gasket, bank 2
Vanos solenoid O-ring
Vanos unit bolts
Cam sensor o-rings
Eccentric shaft sensor o-ring
NOTE:
It is not necessary to replace spark plugs tubes during a course of this repair.
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code 11 37 91 42 00
Labor Operation:
Labor Allowance:
Main work:
00 55 453
93 FRU ? E53 X5 4.4i/4.8is
91 FRU ? E65/66
102 FRU ? E60, E63/64
+Associated work:
00 55 793
91 FRU ? E53 X5 4.4i/4.8is
90 FRU ? E65/66
100 FRU ? E60, E63/64
Note: The following explanations will spell out the correct use of the work times.
Main Work:
Use this labor operation number when the only repair performed is the listed warranty repair.
OR
+Associated Work:
Use this labor operation number when other repairs or services are performed along with the listed warranty repair.
Under no circumstances should both labor operation numbers be claimed. Attempts to claim both times will result in an unnecessary delay in claim processing and payment.
md750i
04-08-2015 06:08 AM
