545i start problem on warm engine
Old Nov 29, 2009 | 12:41 PM
dawid_w's Avatar
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
Hi,
I am having a problem to start the engine when it's warm. Engine starts for 2-3 seconds with around 350-500 RPM and then it dies.
When I try the second time is starts normally and I don?t have any problems.
It is 2005 545i Manual with 92k
I replaced already the Pressure Regulating Valve - Repair Kit.
https://5series.net/forums/index.php?showtopic=85337
After that I am getting much better gas milage, but it didn't fix my problem.
Any suggestions?
Old Nov 30, 2009 | 10:21 AM
jm545i's Avatar
Originally Posted by dawid_w' post='1064555' date='Nov 29 2009, 04:41 PM
Hi,
Any suggestions?
Sure sounds like a fuel pressure problem, like a check valve not holding pressure, with cold starts being pressurized by a different system and so not affected.
Old Nov 30, 2009 | 11:02 AM
dawid_w's Avatar
Thank you for the answer.
Is the check valve inside the fuel pump? Do I need to replace the pump?
Old Nov 30, 2009 | 08:45 PM
jm545i's Avatar
Unfortunately my expertise ends at wild-ass guesses. I had similar problems on an older vehicle with a much less complicated engine and that's what it was (and indeed the check valve on the fuel pump was the issue). If you can isolate the symptoms even further and go to a knowledgeable tech, they could probably diagnose very quickly. Perhaps someone around here will stop by. Sorry I can't be more assistance.
Old Dec 11, 2009 | 10:11 AM
Jake545i's Avatar
My Ride: 2004 545i Sport, 6spd Orient Blue Metallic Complete MTech Kit
Hey Dawid, I've been noticing the same problem on my '04 545i 6 spd. On warm starts, it will start, then die. Then typically has been starting up on the second try.
Have you been able to diagnose your problem?
Thanks for the insight!
Jake
Stranger12
Jan 21, 2021 06:19 AM
thesalboy
Apr 8, 2015 09:13 AM
2004_545i
Apr 8, 2015 04:01 AM
Stranger12
Apr 5, 2015 10:42 AM
