545i Clutch Pedal Bushings
Has anyone on the forum replaced the clutch pedal bushings? I'm getting some side to side movement on my clutch pedal and it also has a slight squeak to it.
I removed the panel under the steering wheel and everything to get the clutch pedal out but I can't remove the clutch pedal pin. Any tricks?
Do you need to remove the whole assembly?
Thanks!
Thanks!
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
Just bump as I feel a slight side by side movement of clutch pedal and I am interested also in this. If you figure it yourself please post
PelicanParts.com
09-10-2015 10:02 AM
