535i - HPFP replaced
Old 10-05-2010, 03:40 PM
ObD
ObD's Avatar
My Ride: 2008 535i 6MT
On Saturday while accelerating got the infamous engine malfunction icon in the dash and the reduced power message on I-drive. Tach went from 2K to about 4K. Pulled over and shut off engine and restarted. Icon and message went away. Yesterday, same icon and message appeared while going to work. Aborted work route and dropped car at dealer. HPFP replaced today and all is well. 25K mi on odo. -933 p/n HPFP installed. Had the DME reprogrammed back in July which fixed the long cranking issues that had developed. Running fine till Saturday.
Old 10-05-2010, 03:42 PM
Persian_535i's Avatar
Originally Posted by ObD
On Saturday while accelerating got the infamous engine malfunction icon in the dash and the reduced power message on I-drive. Tach went from 2K to about 4K. Pulled over and shut off engine and restarted. Icon and message went away. Yesterday, same icon and message appeared while going to work. Aborted work route and dropped car at dealer. HPFP replaced today all is well. 25K mi on odo. -933 p/n HPFP installed. Had the DME reprogrammed back in July which fixed the long cranking issues that had developed. Running fine till Saturday.
ROFL mine went out last Thursday under the exact same circumstances, I took it in to the dealer yesterday (Monday). This is the second time I'm taking it in regarding the HPFP, the first time they "reprogrammed" it what a load of shit excuse my language All I know is it better be replaced when I go pick it up or they are gonna hear an ear full. Oh and my odometer is reading at 31k, F#%* YOU HPFP that's all I have to say for now
Gene's Avatar
hope it stays fixed...
Old 10-05-2010, 03:56 PM
ObD
ObD's Avatar
It's a two step process now. Apparently a bunch of good HPFP's were replaced due to bad LPFP's. First, the LPFP output is checked and its output tested for maintaining pressure. If it passes, the DME is programmed to pressurize the fuel system early when a door is opened with the engine off. After reprogramming if there are further issues, the HPFP gets replaced.
Old 10-05-2010, 04:00 PM
ObD
ObD's Avatar
More of a nuisance. Next May I'll be turning in the car - lease end. HPFP warranty still in effect for 7 more years.
Old 10-05-2010, 04:06 PM
Gene's Avatar
agreed...my lease ends in december...hopefully I can continue to dodge hpfp issues...
Old 10-05-2010, 04:08 PM
PlanB's Avatar
What exactly is the HPFP?? I've heard of this issue but only on 535s and 335s....having a 530 am I safe????
Old 10-05-2010, 04:12 PM
Gene's Avatar
high pressure fuel pump, known issue with bmw FI engines, specifically but not exclusive to the N54 engine...your 530 won't suffer issues from it...
Old 10-05-2010, 04:15 PM
PlanB's Avatar
Thank you for the clarification. Do 550s suffer from this? Pretty sure it's the next ride.
Old 10-05-2010, 04:22 PM
Gene's Avatar
f10 550, as of right now, but is an FI engine with TT V8...the e60 550i: no, again, that engine is an NA V8...the hpfp issue seems to exclusive to Fi engines
***FI=forced induction/turbo engine
***NA= Natural Aspirated engine
Quick Reply: 535i - HPFP replaced
