530xi ???? help!
Old Feb 25, 2008 | 06:21 PM
bahamutzyro's Avatar
just wanted to know if i purchased a new 530xi awd model, can i convert to m5 look? will all m5 parts(body parts) fit on this model? also the rims? will 20" m6 rims or deep dish rims fit? i want this car for the snow since its awd, but i want to mod it out to look like m5 kit. will it work??? thanks in advance!!!!!!!!
Old Feb 25, 2008 | 06:39 PM
seventhirteen's Avatar
My Ride: 2008 535xi, Platinum Grey, Black Dakota leather, Light Poplar Wood, Anthracite headliner, Premium, Sport, Cold Weather, Nav, HUD, PDC, Night Vision, Logic7, iPod / USB, HD Radio, Sunshades, Heated Rear seats, and Folding Rear Seats.
The xi model don't have as many options for wheels. There are previous posts about this, basically you are limited due to the x-drive and different offsets compared to the straight i model. Why not go for the 535i?
Old Feb 25, 2008 | 07:01 PM
luigi524td's Avatar
Do you mean a pre-owned 530xi ? ? Or did you actually find a 'new' 2007 530xi ... or do you mean a new (2008) 535xi?
Any way you go, the body work should not present any problems; the wheels, on the other hand, are specific to the ###xi models and have different offsets than other RWD BMW models.
Old Feb 25, 2008 | 09:50 PM
DrLev99's Avatar
No M5 or M6 rims will fit...out of luck there, buddy. Even if you find an aftermarket wheel you like with the correct offsets for the xi, it won't be a true "deep dish" look. The front and rear axles on our cars are slightly longer that the RWD versions, hence you need to find rims with higher offsets. If you want to go staggered, the OEM recommended offsets are ET43 in front and ET55 in rear. However, you won't find any OEM rims in 19" or higher with those offsets. So, find some aftermarket rims that are close...ET40 in front and ET45 on rear work also with no rubbing, like mine.
Everything else you mentioned for the M5 mods should work, though. Good luck!
Old Feb 25, 2008 | 10:10 PM
DrLev99's Avatar
Ooops...please remove, Rudy or Iceman!
JDeezyNYC
29
Oct 15, 2020 11:48 PM
Bimmer518
Sep 23, 2015 06:33 PM
AirlinePilot
12
Sep 12, 2015 09:39 AM
militantgrunt
Sep 10, 2015 02:31 PM
