530i - rough idle + stalling when hot/hot weather
Probation Members
My Ride: 2004 BMW 530i
umm
used to be a mechanic and still have all my tools..
but how do i know this is the issue ? i'm not the type to just try and see if this is the issue...
havn't seen any other people having the same symptoms as me... i mean...just doesn't make sense.
only happens when very very hot....crazy idle/hunting then stalls...
Hi All
first post here after a high number of searches, but nothing like mine...anyway... hope you guys can help !
2008 530i (i assume it is the N53 engine)
Symptoms: Engine idle hunting very roughly, shaking the whole car and stalling
Conditions: Only on extremely hot days/when driving for awhile (45+ minutes) and very hot weather. Does not occur when engine is cold.
Additional Symptoms: May not be related, but i also have a strong smell of petrol/exhaust fumes in the cabin, which leads me to believe i potentially have a cracked manifold or maybe leaking exhaust manifold gasket...not sure if related though.
I have had a few looks in the engine and underneath and i do have some oil leakage/seepage... can't see from where though.
any thoughts ? a few of my friends have advised it could be a vaccum leak, but if that is the case, why does it happen only when hot ? possible heat expansion of metal causing the leak...therefore only occurs when extremely hot ?
any help or experiences would be great...
thanks guys !!
Geoff
thanks guys !!
Geoff
Hi everyone! First post, new to this forum
I may be late to the party, but I have the same issues on my engine, with one added symptom that points me to a faulty ccv membrane. The additional symptom is a whistling sound coming from the engine, only when it's warmed up and in hot weather, and that's when the idle problems arise. I already checked the air-tightness of the intake with no problems or leaks, checked vacuum lines, the tube behind the engine that ventilates the valve cover, MAF, and various other sensors on the intake. Last thing left to check is the CCV.
I also have an oil leak that falls right on the exhaust that comes from the valve cover gasket, which I will be replacing, but that doesn't seem to be the main issue, just an annoying one. But since I have to tamper with the CCV membrane, might as well replace the valve cover gasket.
I will be back here as soon as get the parts and replace them, see if this fixes the problem.
My Ride: 2008 530i M Sport
Fyi
My issue we found out was the intake solenoid.
replacing it fixed the hunting/stalling.
In saying that, I get an occasional hunt/drop in rpm but no codes showing.
I'll keep that in mind in case the ccv doesn't fix the issue, maybe I'll just clean it to be sure, if possible, but INPA data wouldn't make me think that it's VANOS in this case.
Before this issue I had the same as you, an occasional drop in RPM, but nothing to be too worried about.
