530i N52 - engine almost stalling when pulling away at low revs
Old 12-23-2013, 02:42 AM
Seadooxpseadooxp's Avatar
My Ride: E60 530i M Sport auto
Issue still persists but is definitely better after Vanos solenoids change and oil and filter change.
I have adapted driving style to accommodate so am not 'looking' for the problem all the time. Annoying.
Local BMW dealer - who I get on really well with, have advised me to live with it unless it gets worse as they could quite likely strip all the manifold system down/attack the vanos and still not cure the fault. They said dont spend anymore until it throws up codes/gets worse - I'd be wasting my money with no guarantee of success.
Love to cure it - but it seems to be a trait I might have to live with.
Needs rear tyres soon - so money required for those instead!
Old 12-23-2013, 06:01 PM
ncsugrad2006's Avatar
Sounds like a vacuum leak / CCV issue to me as well
Old 12-24-2013, 01:45 AM
10550i's Avatar
My Ride: 2010 550i M Sport
OP, check the intake cam sensor. I would probably change it since you have changed the exhaust cam sensor. Next would be the electric fuel pump and fuel filter.
Old 03-19-2014, 12:12 PM
seadooxp's Avatar
So far so good - the issue appears to be RESOLVED! I have had the DISA valve replaced in the inlet manifold and the dead throttle issue on full power is gone. Early days yet, but I drove it back home
averaging 42mpg! I tried all the way back to replicate the hesitation and couldn't do it. Here's hoping I've fixed it! The indie I used was top drawer - couldn't recommend enough. DISA was £190 plus labour and VAT.
Kasmo
06-27-2024 06:02 AM
dakest
03-25-2015 07:02 AM
browellm
02-19-2004 10:24 AM
oreo
10-10-2003 04:09 AM
08-12-2003 11:41 AM
Quick Reply: 530i N52 - engine almost stalling when pulling away at low revs
