530i 2007 N52 Oil Consumption
Old 05-21-2013 | 10:55 AM
Jose R. Mota's Avatar
My Ride: 2007 530i (EUR)
Angry 530i 2007 N52 Oil Consumption
Hi, I just purchased a 2007 530i from my uncle. The car is in almost perfect condition, driven with respect and taken care of in the most diligent ways, it had an extended warranty which ended about 3 months ago. The last time it was taken to the dealer it had 45000 km (28k miles) and it had a full service performed under warranty, no issues were found. Now it is out of warranty and has 46500km (almost 29k miles). I decided to fork out the 400 dollars they asked for a full check in a place you would usually call the stealership (only 1 here in the Dominican Republic, "Autogermanica"). Now I have the results, and they are asking for almost 8k to fix a "small oil consumption" in the engine. It kind of fucks my mind up that a car, which has always been driven in a moderate manner, with such low mileage and just out of warranty could develop such an expensive problem out of the blue. I kind of feel they want to screw me up with this quote. What do you guys think? Is it possible? Do you think they might steal some parts from my engine now? What should I do!? There isn't white smoke coming from the exhaust!
I'm confused right now.
Post Scriptum: I will attach a pdf with the quote from the dealer in case anyone understands spanish and their quote. Also, I'm not a native english speaker, nor I have lived amongst any so more than forgiving my mistakes any clarifications are welcome.
File Type: pdf
Old 05-21-2013 | 03:22 PM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Hard to tell what this really is -- it looks like multiple things. There aren't many part numbers on the quote. I see 11517546994, which is a water pump - nothing to do with oil leak there. 11127555757 is a head gasket. I see new pistons. I would argue with the dealer that the car was serviced all along and should be fixed under warranty. If these problems are real and not just dealer FUD (fear, uncertainty and doubt), it didn't just develop this problem and they should have caught the problem under warranty.
Old 05-21-2013 | 06:28 PM
540i's Avatar
Yep, I doubt the car mysteriously developed all those problems in 1000 miles. Either they didn't want to fix it under warranty, or they want to get money out of you now that it's out of warranty. I personally do not trust dealers and I would take it to someone you know or an Indy shop for a second opinion.
Old 05-21-2013 | 08:43 PM
rob2388's Avatar
My Ride: '09 e60 n54 white/black
That's crazy! 8k is way too much money.. i speak spanish and looks like they are replacing a piston? They are raping you on both labor and parts i think.. I say go somewhere else.
Old 05-22-2013 | 05:44 AM
jgt's Avatar
jgt
My Ride: E60
Engine: N52
I never heard or read about an entire engine rebuild on an N52 because of some oil consumption. Looks like you are getting hosed lol.
From what I see they are removing the engine, rebuilding the engine by replacing all 6 pistons and every gasket, new engine mounts, changing your brake fluid (not even sure if this is necessary when removing an engine), changing your water pump (why?? lol) , an oil change, +2k in labor and over a 1k in taxes. A few random parts in there are bolt kits and a few parts I can't make out since the words are cut off.
If you haven't been adding oil, no visible leaks and there's no blue/black smoke coming out the pipe why worry about it?
Get a second and third opinion if you are concerned about it. I personally wouldn't even worry about unless I was adding oil, smelling a strong oil burning smell, seeing visible leaks or blueish smoke out the pipe.
Old 05-22-2013 | 09:34 AM
balbs's Avatar
My Ride: BMW
I would never go back to that dealer again. They are taking advantage of you.
Old 05-22-2013 | 04:31 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
Are you actually losing or consuming oil, or are you solely going off of what the dealer told you?
Old 05-22-2013 | 08:24 PM
Turtlespd's Avatar
My Ride: Ls430
He owns a bmw, he must be able to afford it but of course it just happened over 1000 miles. Take the car else where.
Old 05-24-2013 | 08:27 AM
Hey guys, thanks for your replies, I took the car out and it has been working just fine. I just hope it keeps going like that.
Old 05-24-2013 | 08:39 AM
balbs's Avatar
My Ride: BMW
Clean the engine compartment and take a note of where you see some oils spots. Clean it up and check weekly if the oil spots come back.
Each time you park the car, look under the car and try to notice any oil spots. Before you leave that parking area, check under the car again to see if there are new oil spots.
Also, sometimes the oil level minimum warning on the iDrive can be false depending on engine temperature especially if it has been really cold the night before.
Look for smoke coming from the exhaust.
Just monitor your car. I'm lucky that I have an assigned parking spot at work and at home so I can notice oil leaking or not.
tis66
05-18-2021 08:59 PM
gergnang
02-02-2021 07:29 AM
YannickVT
05-07-2015 11:45 PM
Don dario
04-30-2015 10:59 PM
dakest
03-25-2015 07:02 AM
Quick Reply: 530i 2007 N52 Oil Consumption
