530D Late gear shifting
Old Jun 12, 2009 | 02:26 AM
flup3's Avatar
Thumbs up
Hello,
I have a 530D from November 2003 AUT 350.000Km, that does not shift gears on time.
At stand still, everything is normal.
When I press down the gas pedal, the car accelerates with 70% of the usual speed ,reaching maximum rpm and staying there for +- 5 seconds before shifting to the next gear. This happens on all gears.
When I checked the gearbox fluid, I saw that the plastic transmission pan at the bottom was leaking around its gasket. So I fixed that with liquid-gasket and filled BMW-ATF fluid true the vacuum hole at the top left corner.
With someone in the car constantly shifting between R , N and D , I filled it with +- 4 liters of ATF, until it spilled over.
Sadly the problem has not been solved by doing this.
Does anyone have experience with this issue?
Thanks.
Old Jun 12, 2009 | 04:43 AM
E60Sim's Avatar
Have you tried to reset your gearbox?
Ignition ON (engine OFF ), and hold down the gas pedal (100%!) for 25 seconds. The gearbox will then reset its memory.
It's worth a try.
350.000 km's ?! did you drive all of them?
Also please fill in your location
Old Jun 12, 2009 | 06:38 AM
hey3688's Avatar
My Ride: BMW E61 525DSE Auto Touring. 2004 54 plate Metalic saffire Black, Active Steering. 18 Inch Style 124 Alloys, falken 452s Beige Leather Dark Poplar Wood Trim xenon bulb upgrade blutooth phone prep
It's worth a try.
+1
Old Jun 12, 2009 | 07:53 AM
flup3's Avatar
I tried that, but it didn`t do anything for me .
I bought the car last week in germany with 180.000 on the display.
Then i found the dealer service book under the seat.
Last checkup Apr.2009 at 350.000 km !!!
The *sshole his name : Ter Hoeven Autohandel in Bentheim
Old Jun 12, 2009 | 11:55 AM
E60Sim's Avatar
Wow that sucks
Didn't you check the service book before buying it?
Was the hole front repainted? You can easily see the difference between 180k and 350k kms in terms of stone chips etc.
The easiest way of checking if the KM's are the right one displayed is to give the VIN number to your BMW stealership and they can search the BMW database for warranty repairs. Also if you have a service book in hand and you doubt the mileage, check the dates. If it was serviced on a weekend, it's manipulated (I saw a E36 328iA with that some years ago in the Frankfurt area). If the dates are on workdays, call the dealerships to see if they exist and check if they did perform a service on the car.
Where are you located?
btw this is my post # 1000! woohoo!!
Old Jun 12, 2009 | 11:21 PM
flup3's Avatar
The whole car was been repainted. It seems to have been in an accident.
I'm not to worried about the mileage nor the damage right now.
If the transmission has a problem, the costs will be true the roof !
th3h1ghlander
Oct 9, 2015 07:40 AM
bestofthebest
Oct 2, 2015 03:21 PM
med123
Sep 22, 2015 09:25 AM
fifthofjac
Aug 30, 2015 07:08 PM
AJH
Aug 30, 2015 11:38 AM
