530d Engine Air Filter
Old May 27, 2009 | 04:03 PM
Salvatore's Avatar
Hi Guys,
Want to change my air filter and clean the MAF before I take the car over to Europe mainland.
I've searched and have seen people mention that there is an Adobe PDF of the procedure (for removing engine trim, etc).
Can someone link me to this PDF please?
Thanks
Old May 27, 2009 | 07:28 PM
BLooD's Avatar
Cool
undo screw holding engine cover, lift off engine cover
undo hex shaped screw clips on the pollen filter covers. lift,remove filters and covers
undo remaining hex shaped screw clips, release plastic support in the middle of pollen filter housing. lift, remove whole housing, splits into two parts
undo 6 screws holding down the front strut brace, the brace is under pressure, release screws abit at a time, remove brace
air filter housing is on the left hand side as you look at the engine from the front
remove all screws around the housing, the one at the back is a little difficult to get to. lift, remove housing
pull out old filter and replace
hope this helps, don`t think i missed anything, it`s an involved job just for something so simple. good luck
Old May 28, 2009 | 06:28 AM
Salvatore's Avatar
Thanks matey,
Is there likely to be any difference given the variance of my 530d engine (LCI model)?
Also, I notice you are UK based. Do you have like the standard business satnav radio thing? If so, what methods are you using to upgrade your audio (from your sig)? I'd like to get it sounding better too but was told it wasn't a simple job.
Thanks
Old May 28, 2009 | 07:31 AM
BLooD's Avatar
it`s the same job i believe for the lci engine, i have business nav and pro radio, i added 4 tweeters (front and rear) and upgraded the front mids to l7 mids, its an easy job to do, theres a diy for removing the door panels on this forum some where
Old Jun 6, 2009 | 08:45 AM
Salvatore's Avatar
So, interestingly, I only have 4 bolts hold my strut brace in, and I didnt need to remove it
Took about 45 mins
Old Jun 6, 2009 | 11:20 AM
BLooD's Avatar
glad you was able to sort it, i missed counted the strut brace screws there is 4.
Kasmo
Jun 27, 2024 06:02 AM
socale39
Sep 5, 2023 08:30 AM
gergnang
Feb 2, 2021 07:29 AM
kongse
Jul 17, 2015 03:29 PM
TexaZ3
Apr 8, 2015 10:50 AM
