530d big Consumption Problem
Old Dec 26, 2022 | 03:53 PM
david011's Avatar
My Ride: 530d stage 1
Default 530d big Consumption Problem
Hello im new to this site , Have 530d e61 (218PS) automatic gearbox , with big consumption problem car driven Generally in town drive consumption is around 17Liters - per 100 kilometers OR as YOU like to say is giving me around 17MPG....
I tried DPF Delete EGR Delete with egr coller bypass Stage 1 250PS , New Thermostats .....Nothing happens ..... Before I have e65 730d with same engine And consumption was much lower ...... Does anyone have some idea? Car Running excelent no smoke even on full throtle, stady idling ...... THANKS
Old Dec 26, 2022 | 08:41 PM
donpb's Avatar
My Ride: '06 530i N52
Throwing parts at a problem usually does not end well. You need to have diagnostics performed or learn how to DIY.
Old Dec 27, 2022 | 07:13 AM
david011's Avatar
im not diy , been going to like 20 diffrent mechanic shops , nobody knows what it is ..... first say DPF then EGR i did it all and nothing happens.... car has on dyagnostic oil level sensor failure, (Air con) AUC SENSOR , FOGGING SENSOR, only those 3 errors apear
Old Dec 27, 2022 | 04:35 PM
donpb's Avatar
That sounds odd. Were any of them BMW Specialists? I would not assume just because they say so or work at the dealership that they are specialists. They seem like they are guessing. A true specialist does not guess. Did any of them tell you what exactly did they check? Vacuum leaks? Pressure? Lots of things can cause poor MPG.
mg3091
Jun 28, 2015 12:42 PM
Patrick E61
Sep 16, 2009 04:27 AM
R77 ANO
Aug 29, 2009 05:16 AM
culka
May 11, 2009 03:28 AM
pauld30
Apr 11, 2009 04:14 AM
