525i loud banging knocking noise
My Ride: 5 SERIES
Last night I drove home from about 110miles and on the way home I could hear a loud banging noise. Sounds like a rod knocking or something. I didn't drive it crazy and there are no engine lights or anything. While at idle I tried to see if anything changed if I were to take off the oil cap and nothing. Then I turned the A/C on really quick for about a second or two to see if anything changes and it didn't I was still able to hear the noise. I could hear the noise from inside the cockpit as well. I hope it's nothing drastic and it's just the A/C compressor, one or all of the pulleys/tensioners malfunctioning. Could it also be the chain guide tensioner lose inside getting hit by the chains or something? What else could it be? This sucks I was about to get the transmission checked and rebuilt with this TC ZF 5HP19 Stage 1 Torque Converter (BMW) and new mechatronics if need be. Now I might have to reconsider.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
What year car do you have and how many miles. Why are you getting the transmission rebuilt? Have you checked the pulleys to make sure there was no play in them? What type of oil do use?
My Ride: 5 SERIES
2004 525i e60. m54. I still haven't looked at my car yet since. I'm going to check out the bimmer tomorrow. I'm sad I really like the car I was going to get EVERYTHING replacednexcept for engine internal work. Hopefully it's nothing internally and it's just a A/c compressor or something.
My Ride: 5 SERIES
I now think it's the A/C compressor and pulleys. When I do turn the A/C on max the noise dies down a lot. Is there any way to disconnect the A/C compressor?
My Ride: 5 SERIES
So I can just unplug the compressor. Should I cut the A/C belt as well until I get a new compressor and belt? Would It be ok to drive tot he A/C shop with the compressor unplugged and the a/c belt cut? It shouldn't matter if that's the problem right?
My Ride: 5 SERIES
So I took all the fuses that deal with the A/C and I disconnected the ac compressor. I also cut my compressor belt and the noise was gone! Now i'm gonna order all the belts and tensioners and get that done. I also noticed my control arm is worn. That should be an easy install right?
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
rackhacker9275
05-14-2015 01:38 PM
