525i Active steering issue
Probation Members
My Ride: E60 2006 525i
525i e60 2006 with Active steering
Getting Active steering error . have the following codes
612C AL: Control Unit Hardware fault
6145 AL: Angle sensor relation - no monitoring
CE93 : Message Steering wheel angle , 0xC8 Faulty, receiver active steering, transmitter SZL
When car is started, tries initialization, the steering wheel moves by itself to a position off centre, then error beeps on screen
So far, based on my research on this forum have tried;
1. removed steering wheel and cleaned the SXL disc (it was very dirty/sticky)
2. checked for water damage on module under front right carpet. no signs of water damage or corrosion on unit, cabling or connectors
3. the reset procedure ie steering to left / right, centre then switch off car etc
issue is still there. are there any other suggestions? was thinking of replacing module however want to see if there is anything further to check?
Thanks
Thanks
NoName545i
04-15-2020 01:19 AM
