2AA8 Error Code - N52 2008 530i
Old Jun 24, 2021 | 12:51 AM
geo41e's Avatar
My Ride: 2008 530i M Sport
Default 2AA8 Error Code - N52 2008 530i
Hi guys.
Wondering if anybody out there can give me some help here.
So I ran a scan via BimmerLink and BimmerTool Lite, got the following error:
*2AA8 - 2AA8: 0x2AA8 variable intake system actuator: control*
After clearing the code, and went for a drive and then rescan. Code came up again.
Note - No engine light at anytime, however did feel a slight stutter/hunt on idle.
Did some reserarch, and can only find a relation to the DISA valve.
So I monitored the DISA valves live via a dashboard, and the readings are:
After Code Reset
Actual DISA Position: 5%
DISA1 - Large: Spiked to 70% During start up - then stayed on 15%
DISA2 - Small: Spiked to 70% During start up - then stayed on 15%
After Scanning and seeing 2AA8 Code:
DISA1 - Large: 15% (Even during start up)
DISA2 - Small: 15% (even during start up)
I now have tried to replicate the above, but for some reason I can't. That is, after clearing the code - when I crank the car or go on reds, DISA 1 and 2 will just stay on 15% value.
Wondering if anybody here has any recommendations moving forward ?
I'm thinking of taking out the DISA and see if it actually moves as well as if it moves when I go on reds... problem is, I'm not even sure where the DISA is, even after looking at RealOEM exploded diagrams...since there are two units ?
From RealOEM
Thanks in advanced for any help guys
Old Jun 24, 2021 | 01:24 AM
geo41e's Avatar
sooooooo
Had a peak...and saw this:
...think this might be the cause
thing is...i cant find the bloody cable now...
Old Jun 24, 2021 | 02:16 AM
geo41e's Avatar
So guys..
found the cable and all is well..
Admin, if you wanna delete this thread.all good
Sorry for the lack of attention to detail on my part !
Old Jun 24, 2021 | 03:14 AM
08535's Avatar
My Ride: 08 535i M sport package
Model Year: 08
Engine: N54
Glad you found it. What did you do unplug the cable and forgot you unplugged it and where it went? 😏
Old Jun 24, 2021 | 03:23 AM
geo41e's Avatar
lol
So a few months back - maybe 3 - 4, my mechanic replaced all upper seals on the rocker cover and Oil heat seals ?
Now that time till now Ive had no engine lights, however after getting my BT - OBD adapter + Bimmercode and Bimmerlink...the scans showed that 2AA8 error...
So I'm assuming my mechanic didn't plug it back in...
I'm surprised it didn't throw any engine light/limp mode ?
May 6, 2021 07:19 PM
jojot
Jul 23, 2014 11:02 AM
bigchris
Dec 4, 2013 06:05 AM
oslouie
Jul 10, 2013 11:04 PM
zimasha
Apr 2, 2013 02:46 PM
