2A82 Vanos Inlet
Old Feb 17, 2025 | 06:27 AM
Captain_America's Avatar
Probation Members
My Ride: e60 523i 2006
Exclamation 2A82 Vanos Inlet
Hello I have 2006 bmw e60 523i. I got a vanos inlet issue swapped both soliniod but still getting issue in inlet any suggestion what should I have to replace now thank you. Also when I changed my oil last time it was too much dirty and I realised I changed too late I should changed in every 5k miles thank you
Old Feb 17, 2025 | 07:01 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
You swapped both solenoids with what? If you used OEM and the connectors and wiring is good then it's time for a new inlet adjustment unit with new wheel. Pull VC off and have a look.
Old Feb 17, 2025 | 05:15 PM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Just buy new ones. They are old at this point. I've had the issue long ago and cleaning them didn't really fix it, but new ones did.
Old Feb 18, 2025 | 06:21 AM
Probation Members
Thankyou for your responce. No I didnt use OEM I just clean them and put new o ring to them and shuffle them to see if its comes to oulet or not but the issue is still comming on inlet also my cylinder is misfiring as well
Probation Members
Old Feb 18, 2025 | 06:24 AM
Probation Members
Have tou got the same issue like shuffling them doesnot fix. I wonder if I chnaged them and still the issue comes up then there will be something else.
sumu
Sep 7, 2009 03:46 PM
Bob525D
Apr 28, 2009 12:31 PM
dieseltouring
Mar 29, 2009 01:42 AM
Mike's 530i
Mar 5, 2008 09:28 PM
newbiebimmer
Oct 15, 2007 05:20 AM
