2010 550i oil leaks
#21
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
Oil leaks are really a big problem for BMW and it is shame and anoyng to see a oily engine. Why MBs engines are not leaking that much as BMWs do. I still think that the main problem is their 50k free maintenance plan. If you go with 5k mile oil change from the beginning the gaskets and seals would last much longer. But most first owners lease the car and they do not care if it will start leaking oil or not after.
#22
My Ride: 1997 550i
I am in the process of replacing the valve cover and timing cover seals (among other things) on my 07 550i with the N62 engine. I have run into an obstacle with the left timing cover that is listed no where in any manual that I can find, or on any forum either. Specifically, there are 2 metal lines that run in front of the left edge of the timing cover, and curve under the cover, blocking the ability to remove the Torx bolt at the left corner. Furthermore, there is a bracket bolted to the UNDERSIDE of the engine just behind the timing cover that secures the lines in place, so you cannot just pull them to the side. Please refer to photo. I cannot imagine getting to this without pulling the engine, but everything that I have read states that the gasket replacement does not require engine removal. So.. HELP! If I must remove the engine, how much of a PIA is that? I also intend to replace the alternator bracket oil gasket too...if that would influence the decision.
Thanks for any help!
#23
My Ride: 2006 550i, 6 speed manual
Unfortunately when buying pre-owned you don't have a sense of how well or poorly the previous owner treated the vehicle. This alone could explain the number of oil leak issues you're now experiencing.
#24
My Ride: 1997 550i
Actually, I bought the car new. The car was maintained per the dealership until the coverage ended, since which I have changed the oil every 5K miles. I only have 70,000 miles on the car. I am not sure whether the long oil change intervals that BMW performs is a contributor, but they definitely use cheap and crappy material for the seals. The valve cover gaskets that came off are like brittle plastic. If BMW wants to keep using crap material It would be nice if the aftermarket would produce Viton seals or equivalent so that those of us who want to do this only once can be done with the problem. Just my 2c worth as I am dealing with the problem...
#25
My Ride: 2005 545i, N62, Manual trans, dynamic drive & active steering
The rubber sealing gaskets aren't the only problem pieces on the car, I'm talking about every single rubber component and rubberized plastic part of the car, except for the tires...
But in the end, I still want my M5, so I'm willing to endure the endless pampering required of these "high-maintenance women".![Big Grin](https://5series.net/forums/images/smilies/imported/biggrin.gif)
