2008 550i jammed trunk
Old 01-28-2015, 10:03 PM
Nathan Calvin Saunders's Avatar
My Ride: bmw 550i 2008
Originally Posted by turboawd
ok i just went and checked my car again. at about -40 degrees, i can feel more resistance, and from there to almost -60 degrees is when the latch actually unlocks.
did you slam the lid shut?
Yeah I slammed the lid and it stops at -40 degrees
Old 01-28-2015, 10:04 PM
no. there is carpet backing in trunk.
Is it thick or would I be able to cut through it so that I can reach the latch in the trunk
Old 01-28-2015, 10:26 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
its not that thick. thats assuming there is no metal backing behind the seat. then lets say you can reach in. what would you do? you couldnt reach the latch. and you'd have to tear out the carpet from the lid also.
i'd have someone keep pressure on the key, while pushing in and out on the lid by the latch and maybe pushing down hard on the lid.
Old 01-28-2015, 11:02 PM
Very true, I will try that if that doesn't work I will just take it to a bmw auto shop, really don't want to have to replace a trunk lid
Old 01-29-2015, 07:24 AM
Finally got it, I had to unlatch the two hooks by the lower part of the seat near the door to lift up the back seat
Old 01-29-2015, 08:18 AM
sanjsanj's Avatar
My Ride: E60 530d
The lower part of the back seat lifts off easily - are you referring to the backrest part of the seat? Pictures would be handy!
Old 01-29-2015, 10:01 AM
turboawd's Avatar
so you got in the trunk, but were you able to open the lid?
Old 02-02-2015, 06:33 AM
Yeah, the problem is the key, the wire isn't connected for the key to work so I jump started the car, I still had one cable attached to the battery, and I was able to open the hood with the remote and the button on the inside, thanks for the suggestions everyone
dsummersm3
11-14-2019 07:50 AM
kongse
07-17-2015 03:29 PM
ksags6756
04-22-2015 09:38 AM
Skavilla
04-21-2015 03:43 AM
jl21
03-29-2015 09:53 PM
Quick Reply: 2008 550i jammed trunk
