2006 E60 oil removal
Old Dec 29, 2014 | 10:54 AM
Gulfsurfer's Avatar
My Ride: 2006 530i, 2000 528i
Default 2006 E60 oil removal
I used to remove my E39's oil during oil changes through the dipstick using a manual vacuum pump. This method doesn't appear to work on the E60's engine; there's no dipstick!
Has anyone found a way to avoid draining the oil from below?
Old Dec 29, 2014 | 11:22 AM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
What's wrong with using the drain plug?
Old Dec 29, 2014 | 12:09 PM
EddieboyS's Avatar
My Ride: 2006 550i, 6 speed manual
You have to go underneath to change the filter anyway, no?
Gulfsurfer's Avatar
Nothing is wrong with that per se, but once you change the engine oil by sucking it out the dipstick, you never want to go back to using ramps, a creeper and a drain pan again. I can do my E39 from the top in about 10 min and not spill a drop of oil.
My dream garage will have a four-post car lift for doing this kind of maintenance and I could do it from the bottom a lot easier then. But building that dream garage appears to be a long time from now!
Old Dec 29, 2014 | 12:10 PM
Gulfsurfer's Avatar
Both my E39 and E60 oil filters are changed from above, in the engine campartment.
Old Dec 30, 2014 | 10:49 AM
EddieboyS's Avatar
Ok, 550i is underneath.
Old Jan 1, 2015 | 03:07 PM
txag_530i's Avatar
There's no way to suction the oil out of the N52 engine.
Koqui79
May 24, 2015 06:47 PM
kane1111
Apr 10, 2015 04:40 PM
Adam1v
Apr 5, 2015 11:40 PM
BYS2
Mar 30, 2015 05:33 AM
ZeZe
Oct 15, 2003 12:58 PM
