2006 BMW 550i Starting Problem
Old 05-06-2010, 08:11 PM
walt's Avatar
Thanks for all the comments. Too bad I still had time to turn the music off and it was still failing to start.
I am thinking fuel pump or fuel filter.
That said, I hear ya about the mexican food!
Old 03-16-2012, 02:23 PM
Cinder's Avatar
My Ride: '06 E60 550i
Bumping an old thread, but my '06 550i just did this twice today, never happened before. I recently had my injectors cleaned, as I was having some very slight vibrations when idle (no RPM fluctuations), I see that walt had his replaced. I wonder if you found out what was causing this.
Old 03-16-2012, 04:08 PM
Cricketts's Avatar
My Ride: 2010 BMW 550i M Sport. GPS, Satallite, Active suspension, Silver over Black in color with beige. 68k on the clock. My 10th BMW in forty years.
Model Year: 2010
Engine: 550 Msport
Old 03-16-2012, 04:10 PM
Cricketts's Avatar
Model Year: 2010
Engine: 550 Msport
Me also! When it died, the dash indicated fuel problem.
Old 01-09-2013, 12:05 AM
Cinder's Avatar
I believe I had the exact same problem as the OP, at least mine looked identical as his vid. Turned out to be an injector in my case. It was probably leaking very small amounts of fuel after the car was turned off, which caused the long cranking afterwards.
I replaced all 8 and the problem has never occurred since.
Kasmo
05-07-2019 03:30 AM
SFx550i
04-14-2015 05:00 PM
Sibby1979
04-05-2015 03:59 AM
Sibby1979
03-18-2015 05:27 PM
rkilpa
03-10-2015 08:24 PM
Quick Reply: 2006 BMW 550i Starting Problem
