2006 Bmw 550i oil leaking pretty bad
Old 11-20-2018, 12:33 PM
NFJ79's Avatar
My Ride: 2008 550i E60
Engine: N62
You said your oil filter was tight, but is the drain plug on the oil filter housing tight?
Old 11-22-2018, 02:27 PM
Jim165's Avatar
Alternator bracket seal is my guess..
Old 11-23-2018, 06:51 AM
hardnard3's Avatar
My Ride: 2006 Bmw 550i
The oil leak looks like it could be leaking around the filter cap area but the filter cap and drain cap drain plug was tight. Maybe Filter cap O-ring went bad. I changed the oil myself a little over a month ago.
Old 11-23-2018, 08:30 AM
audiophool's Avatar
My Ride: 535xi
^did you put some oil on the new o-ring before cranking the cap on? If you don't lube the o-ring, it can wrinkle or tear when you tighten the cap.
Oh, and when you're looking for leaks, start high. Unless they're pressure leaks, gravity makes them start from the top.
Old 11-28-2018, 04:50 AM
hardnard3's Avatar
Yes I put oil on the o ring. Question? What is about the above the oil filter cap and drain plug? ( oil hoses)?
Old 11-28-2018, 04:51 AM
hardnard3's Avatar
Because it was leaking around cap and drain plug
Old 11-28-2018, 07:20 AM
audiophool's Avatar
My Ride: 535xi
The oil filter cap threads into the oil pump housing, which is bolted direcly to the bottom of the engine, inside the oil pan. There's only an o-ring style 'profile gasket' between it and the main part of the oil pan. Is your oil filter cap maybe cracked?
Old 11-28-2018, 07:29 AM
audiophool's Avatar
My Ride: 535xi
I'd suggest removing the underbody covers and have a really good look around. Pictures would really help.
Old 11-28-2018, 07:38 AM
hardnard3's Avatar
Ok great I will get back to you once I take the under body cover offf thanks a lot
Old 12-03-2018, 04:49 AM
hardnard3's Avatar
Could this be my problem? The bottom of oil filter
Could this be the oil leak issue?
Quick Reply: 2006 Bmw 550i oil leaking pretty bad
