2006 5series low beam HID bulb replacement
Hi all,
I recently replace one of the low beam HID bulb.
The shop I went did the job with D1S bulb.
It works fine but the problem is that the color of the new bulb is yellow (a bright yellow)
As soon as I start the car, the new bulb is white, same as the factory HID.
But it changes to yellow color in few seconds.
Has anyone had this problem?
Thanks for sharing.
Thanks for sharing.
My Ride: BMW E60
Model Year: 2016
Find out of the temperature of the bulb is the same?
But honestly, it's recommended to change out both bulbs together if one goes out because the bulbs themselves color shift over time. Except for a particular few, which are more expensive.
My Ride: 520i ('04)
Always replace both bulbs.
Ok, just did a swap with a factory HID bulb, and it still turns into yellowish color after few seconds.
I remember when I first purchased my E60 (it was brand new), the low beam lights did not have the yellowish color.
Is it normal to have yellowish color for relatively new HID bulbs?
My tech guy told me it will take some time to burn the gas and the color will change.
Btw, I agree with you nomis_nehc.
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
Please do search..there is an extensive thread here about that!!!!
