2005 525i - Engine Oil Leak
Old Apr 25, 2017 | 10:10 PM
crustboy's Avatar
My Ride: 05 525i
Default 2005 525i - Engine Oil Leak
Hey everyone, first time poster, long time lurker.
Have a engine oil leak dripping onto my exhaust and getting burnt into smoke. Would this be a DIY or take it to the shops?
Thanks for the help!
Old Apr 27, 2017 | 04:00 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
valve cover gasket, simple DIY. google M54 valve cover gasket replacement. can be done in an hour or less on E60. good luck.
Old Apr 27, 2017 | 05:13 AM
petch's Avatar
My Ride: 2006 525xi
Default Valve cover
I'm debating on doing mine myself, due too cylinder gaskets 3,4,5 are on their way out. I noticed when I recently did my plugs and ignition coils. Main questions are do I need to adjust valves? Second I have two bolts that snapped off how difficult would this be to tap out because they are aluminum.
Old Apr 27, 2017 | 01:28 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
Originally Posted by petch
I'm debating on doing mine myself, due too cylinder gaskets 3,4,5 are on their way out. I noticed when I recently did my plugs and ignition coils. Main questions are do I need to adjust valves? .
M54 has hydraulic valve lifters, no adjustment required (or possible).
Old Apr 27, 2017 | 02:04 PM
petch's Avatar
My Ride: 2006 525xi
Default N52
sorry mine is a 2006 525xi. Would adjustment be required?
Old Apr 27, 2017 | 02:25 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
no. the last production BMW engine that had solid lifters and needed valve adjustments was the S54, which has been out of production for over 10 years. the last non-M engines that needed valve adjustments were the M20 and M30, which ended production in mid-1990s..
Old Apr 27, 2017 | 02:33 PM
petch's Avatar
My Ride: 2006 525xi
Thanks you. Great to know the additional information as well
Old Apr 27, 2017 | 02:40 PM
OEQS's Avatar
My Ride: E60 530i 2010 y E60 525i 2007
Exactly, according to KyleB
