2004 E60 Import - Software upgrade
My Ride: 2004 530i
Hi all,
New to this site and looking for some advice. I'm based in Dubai and have just bought a lovely second hand 530i E60. The problem is that its a Japanese import and I've been told I need to get a software upgrade??
Can someone advise if I need to go to the dealer or if I can download it online then upload in the car? If so, where would I plug it in?
Looking forward to your advice
Cheers
Jon
PS - awesome car!!!!
Cheers
Jon
My Ride: E60 530d
software upgrade? I think the only major thing that you'll need is to change the setting of the iDrive so it tunes into the FM of your local area...
This requires ncsexpert and an OBD cable
My Ride: 2006 530xi w/Sport, Premium, Cold weather. Silver Gray Metallic, Black Dakota leather interior.
Probably going to need a nav disc too. Who told you you'll need a software upgrade? Is that all they said?
My Ride: 2004 530i
Thanks guys, awesome help. Think i can manage that by myself. Download ncs expert onto mem stick and plug it into OBD cable port next to the bonnet release. Go through iDrive system and upload?
Will have to buy satnav disk then.
Yes, the stupid dealer I purchased it off said I would have to upgrade software, not bimmer dealer. Benefit of the doubt, he probably meant what you gents are talking about.
Just out of interest, any of you experienced a small oil leak from bottom of the engine. Cannot find the leak anywhere on top half, its only very small but want to check it out. Got a feeling its the value gasket. Common problem?
Cheers in advance
Jon
Cheers in advance
Jon
Cheers in advance
Jon
Cheers in advance
Jon
I don't know what that first part means.
Valve cover gasket is a common leak point.
My Ride: E60 530d
contact Ehssan
Either here:
View Profile: ehssan - BMW Coding Forum
or here:
5Series.net - Forums - View Profile: Ehssan
He's in your area and is very knowledgable!
![Smile](https://5series.net/forums/images/smilies/imported/smile.png)
My Ride: 2004 530i
thanks guys. Took the beast into a recommended garage and it turns out it needs, new Valve cover gasket, oil filter housing gasket sump gasket, pressure value, vent pipe, connecting pipe, hose, vacuum hose, intake gasket set, v belt and AC belt.
To be fair the AC was leaking as well so just getting everything sorted out. Would do it myself but I dont have the time. Total cost quoted is $1361....?
