2 Minutes!
Old 06-24-2004, 10:58 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by Olivin530i' date='Jun 24 2004, 12:47 PM
I park my E60 in the garage with the wall pretty near my front and have to reverse out in the morning. The screen is forced to return when the reverse gear is chosen and PDC senses the wall in front.
I think you're missing our point.
I, too, park close to a wall and have to reverse out in the morning. The PDC comes on in reverse but will not show the graphic display -- only the audible warnings.
The display stays on the BMW screen as if it's still initializing something.
Old 06-24-2004, 11:01 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by NickP' date='Jun 24 2004, 01:24 PM
There are settings in most nav systems to NOT power on the system if the temps are below -30C, or above +85C degrees.... In conditions like this the system will hold off power up until it finds the temp is more within spec's.
There is a REMOTE chance the thermal sensor/resistor is thinking it's outside tolerance. If this still happens report it.
BTW: BMW's don't seem to like key in the ignition with the car off. My old E46 nav would lockup when this occured.
Our problem is clearly not related to temperature.
The screen actually does come on, it just stays on the BMW screen (before the accept screen) for some time and then goes blank just before coming up normally.
You can tell you're in the initialization phase because while the BMW screen is showing, my US car is showing Kilometers and Celsius readings in the instrument cluster instead of Miles and Fahrenheit. The correct readings show up just before the accept screen finally comes up.
Old 06-24-2004, 11:24 AM
JDN
JDN's Avatar
I just did another wake up, fire up routine and again, before the garage door got moving good, the accept screen came up. However, this time PDC reacted differently. A steady tone came on before the accept screen because the garage door was just beginning to rise. The PDC screen never came on voluntarily even though I backed out like I was going somewhere.
One good experience does not necessarily a problem solve with Mr. E60.
Old 06-24-2004, 12:24 PM
Stu in Austin's Avatar
Rudy, forgot to mention the Kilometers/centigrade thing on the computer...you can actually watch the temperature reading and know for sure that once the temperature begins to show in farenheit that the display is about to come up.
Pretty weird; but should be something that is easy to understand for the engineers who designed the firmware on this thing.
Old 06-25-2004, 06:16 AM
Well, I took my keys out last night (w/out locking the car) and to my astonishment, it took less than 10 seconds this morning for the I-Drive screen to boot up! Looks like leaving the keys in the ignition overnight is somehow the culprit...
Pretty weird, but I can definitely live with this "fix".
Stuart
Old 06-25-2004, 07:07 AM
JDN
JDN's Avatar
Sounds good. I'm curious, Stu, did you have your door closed and seatbelt fastened before inserting key?
Old 06-25-2004, 03:14 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I left my keys in last night and this morning the screen came up without delay.
JDN, I always seatbelt right before starting the car. It's something I do unconsiously so the seatbelt theory may or may not be something to look into further.
The fact that some mornings it takes a while for the screen to come up and some mornings it doesn't (with all other factors being the same) kind of shoots down the key theory as well.
I guess we'll have to keep gathering data to see if we can reliably duplicate the condition.
Old 07-10-2004, 07:47 AM
JDN
JDN's Avatar
Rudy and Stu, try seat belting after you fire the engine. This morning I:
1. turned the ignition
2. fastened the belt
3. activated the garage door
4. fired the engine
5. engaged reverse and started backing slowly
6. the PDC screen came up before the accept button.
7. went back into the garage
8. repeated the sequence
9. again, the PDC screen was giving me what I needed before the Accept screen came up.
10. PDC screen stayed and kept telling me about the tall grass behind the car on the ROW.
11. I punched the iDrive and got the Accept screen which had been patiently waiting.
Old 07-10-2004, 09:23 AM
PeterT's Avatar
My Ride: May 2004 525 Amethyst grey, Heated front seats, bluetooth prep, Adaptive Xenons, 6 CD changer, Front & Rear PDC, retro-fit 6 DVD changer in boot (trunk) with remote control plus headrest screens and IR headphones, Playstation connection to cabin, twin 12v outlets in rear cabin
On my May 2004 525 there is no BMW logo that comes up before the screen reverts to normal iDrive information. Maybe the logic is different in different markets...
Old 07-10-2004, 09:42 AM
JDN
JDN's Avatar
Ah, PeterT, that is the diff btwn Scotland and us USers. We have to live with the disclaimer.
Incidentally, my US ancestors married in Inverary and sailed from Scotland in 1775 with roots in the McNichol (MacNeacail) clan. We be cuzzins?
