2 Fault messages on the I-drive
Old Mar 3, 2012 | 09:39 PM
BIMMERTIME-07's Avatar
My Ride: 2007 525I
Was up everyone one,
Just recently for the past week, My traction and brake light have been coming on at the same time. The traction message is reading, Driving Stability. Reduced driving stability in curves. Drive moderately!
The brake message reads, Start-Off assistance. Start-off assistance inactive Caution, vehicle may roll back!
Anyone have any ideas of what this could be? Is a big issue or just a minor problem.
Thanks for everyone's help and info.
Old Mar 3, 2012 | 10:01 PM
aretardedorange's Avatar
I had those errors a few months ago. It was the steering angle sensor. BMW replaced the sensor and the problem went away. You will also notice the blinker does not stop blinking when you complete a turn....have to turn it off manually. If you are under warranty take it to BMW. Otherwise you are looking at a $500 part+labor (programming) repair.
How many miles are you at? This error occurred for me at 45k miles.
I looked at my repair sheet and this is the sensor, SZL, that was replaced. # 61-31-9-111-997.
Old Mar 4, 2012 | 09:28 AM
My Ride: 2007 525I
Yeah I am approaching 41k. I have noticed when I turn the blinker must be shut off manually. I will try and get a quote from a dealer, but I will most likely take it to a euro repair shop. My warranty is over :thumbsdown: Thanks for your help and info, I really appreciate it.
Old Mar 4, 2012 | 11:46 AM
gcvt's Avatar
My Ride: 2008 550i - Sport Package, Sport Transmission, Active Steering, Navigation, Comfort Access, 7 Logic Stereo
I had the same issue recently and was ready to take it in. I was also due for a new battery. I put in the new battery myself and all the error messages went away.
Old Mar 8, 2012 | 05:37 AM
mjojom's Avatar
how about you just reset angle sensor and then reinitialize steering sensor? if you have active steering, after power failure (disconnecting battery) you must reinitialize the steering sensor. if you have power steering, its worth trying first too.
Old Mar 22, 2012 | 11:44 AM
jfondell's Avatar
I have the same fault as of today except I have Tire Pressure Monitoring Fault instead of The brake message reads, Start-Off assistance. Start-off assistance inactive Caution, vehicle may roll back! any ideas? if so please add instructions if possible as I am new to the BMW.
Thanks
James
Old Mar 22, 2012 | 12:22 PM
luigi524td's Avatar
Thanks
James
When so many assorted warnings start to appear my first thought is BATTERY issue. If your car is still under warranty (hope and pray) get to a dealer to diagnose the issues.
Old Mar 22, 2012 | 02:57 PM
jaycal3's Avatar
My Ride: 04' 545i, Sport Package, Black, Active Xenon, ARS, Aux Input '10 Tahoe, Black on Black, leather, Nav/XM, 20" tires, full body kit, power 2nd row, loaded '93 Jeep Wrangler, lifted 4.5", 33" meats, Rampage Recovery Bumper w/Tire Swing, etc 25' Aquasport Osprey, Center Console,2012 200 HO Etec
x2.. battery...
Old Mar 22, 2012 | 03:40 PM
jfondell's Avatar
Can I just get a battery at the local parts store?
FYI I just put new suspension kit on the car 2 days ago? Eibach springs and Koni shocks
Old Mar 23, 2012 | 01:56 AM
tonyb635's Avatar
you sure can. Autozone has a direct replacement. Get the GOLD battery and compare the Ah & CCA numbers to the new battery. I did this and have had no problems. Dealer cost was $650.00 !!!! If you get a battery with different numbers you may need to program it to the car, otherwise a simple registration should do ya. Some register and some don't, an Indy shop is cheapest.
