2 fault codes
My Ride: bmw e60 msport
Model Year: E60
Engine: 2.5
Hi all can ye help me 2 day i pulled up at traffic lights and car started to rev up and down like mad and than stop if i start after 20 mins it was ok again 2 codes dme/dde 2e8e and 2a98
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
2E8E is a code for the IBS. Could be bad or need a new battery. Did you have your battery replaced recently.
2A98 is a VANOS code the unit could be going bad, the hook ring seals or Vanos solenoid inlet. Once you figure it out change oil
Model Year: E60
Engine: 2.5
take what apart.i also looked up on net that code is related to the camshaft sencor wud this be true and were can I find this
Model Year: 05 530i
Engine: 3.0 M54
I hope it is your camshaft sensor but I don't see those failing too often. The possible issue I gave was the most common. How many miles do you have
linxuan
E39 Discussion
03-22-2015 06:16 AM
