19" M6 Wheels in Canada
Old Jun 28, 2009 | 02:43 PM
theXman's Avatar
My Ride: 2004 530i
Originally Posted by Bteljuice' post='926657' date='Jun 28 2009, 04:11 PM
why dont check out the Miros, Many people around here recommend them? Cheaper and quality replicas. Many on this forum have them, check their sig. GL
Miros are good, but they are not hubcentric, so hubcentric rings are required if vibrations happened. Just keep this in mind.
Old Jun 28, 2009 | 05:10 PM
+1 for Miros, they make a replica of the M6 wheel. and yes hubcentric rings are required with those wheels.
Old Jun 28, 2009 | 09:41 PM
Scoops's Avatar
Could you explain this a little bit better? I'm not entirely sure what that means, excuse my noobiness.
Old Jun 28, 2009 | 09:50 PM
Alpine White Girl's Avatar
i dont know if you are interested in 20in m6 miro reps but i am currently looking to sell mine! they are nearly brand new. they have exactly 406 miles on the entire package! please take a look at my sig for pictures and a link to the thread!
Old Jun 28, 2009 | 09:54 PM
Scoops's Avatar
Originally Posted by Alpine White Girl' post='927005' date='Jun 29 2009, 01:50 AM
Hey, thanks for the heads up, I replied to your PM.
Old Jun 28, 2009 | 10:02 PM
Bteljuice's Avatar
Miro's dont have the same bore size as the BMW OEM. I think they are slightly bigger, thus causing the wheel to move a bit causing vibration. Hub centric rings are rings that you put between the Rim and its fitment. It fills the void between them and thus wont let the rim move, Perfect fitment.
How about you give Trinity or Eurorev a call.
Old Jun 29, 2009 | 07:41 AM
Scoops's Avatar
Another update, and another question...
I called BMW again as I'm also interested in potentially getting 172s, once again they never fail to amaze me with their prices, they've told me it would be $4000 for the set with tires... Where are they getting these numbers from? I'm certain Canadian dealerships are much much more expensive than American ones...
What do you guys think about 172's on my car?
Also, the guy on the phone told me the 172's wouldn't "work" with my car because it's an XI and it is all wheel drive... That doesn't make sense to me.. How does that affect whether or not the wheels fit?
Old Jun 29, 2009 | 08:13 AM
BlaSTiWi's Avatar
'cuz XI model has a higher/bigger offset number than the RWD model. Due to the AWD setup the XI has 23mm addition to the hub.
You can put any OEM RWD wheels no problem but it'll protrude outside the fender and makes it look wrong. What you should be looking are the wheels from the E9x (3-series) if you want OEM setup those wheels will fit perfectly.
GL!
Old Jun 29, 2009 | 12:49 PM
TEAM M's Avatar
I have 20" Vossens on my E60 no hub rings needed...My car rides nice and smooth...
Old Jun 29, 2009 | 02:58 PM
too solid's Avatar
My Ride: 2009 Ford F-250 Harley Davidson Edition 6.4L OHV Power Stroke Turbo Diesel V8 (350hp/650lbft) Blue Flame Package Dual Alternators Touch Screen Navigation + DVD Player Uplifter Switches Trailer Brake Controller Traction Control Rapid Heat Supplemental Cab Heater Rear View Camera Power Slide Moonroof
Canadian parts are way more expensive then US. If I were you I'd go for the Miro replica's. I had them and never had any vibrating issues, and they looked the exact same. I bought mine when the CND dollar was higher then US. I paid around $2300 CDN shipped. The rate isn't bad right now, I say contact Trinity and go for Miro's.
Johnny B
E34/E28/E12 Discussion
Feb 25, 2019 06:34 AM
rorschach76
May 30, 2015 06:02 PM
Johnny B
May 28, 2015 04:09 AM
HeartofDavid
Apr 18, 2015 04:34 PM
stillak
Apr 5, 2015 03:21 PM
