13volts but car won't start
My Ride: Bmw 520d m sport
Hi everyone, can anyone help I have 13.4v showing on my battery but the car will not start, this has happened a few times in the past few weeks and this time it won't even crank, a booster pack will not start it, the only way to get it started is using jump leads off a "running" car.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Let me get this correct.
Your car only start when you jump it from another car.
You won't get a crank or start with just using your battery to start.
At what point of the car are you testing your battery? I would test at the battery and the jump post. If testing at the front post and you're not getting the voltage you got from testing at the battery then you have a cable issue in the rear somewhere.
Model Year: 05 530i
Engine: 3.0 M54
You didn't respond to if it cranks with just your battery.
Also what year and more do you have
My Ride: 530d msport Lci 2007
Sounds exactly like the problem i had, did you try the jumpstart pack on the battery or the jumpstart points under the bonnet? Try this as an experiment, remove the battery and take it to the front and connect it to the jumpstart points with leads. Yes no battery in the boot for trial.
Model Year: 05 530i
Engine: 3.0 M54
I would say since it cranks with another car and doesn't with your battery there is an issue with your battery (how old is it) not enough power to turn over the starter, disconnected cable coming from the rear. Your battery definitely is too high without the car running.
Those are your only options since you can get the car started
My Ride: 2006 530xi (One black & one grey) 2010 X5 535d 1974 BMW 3.0CS 2008 535i, 2009 335d, 2011 X5 35d, 2008 335i FBO
Or, . . . . .you could just have a bad grounding strap between the chassis and the engine assembly (engine mount) which is why it only starts when jumped from another vehicle. When use the booster pack, try putting the grouns on the engine assembly. . . . . .
