08 535xi engine malfunction & fuel pump
Old 06-26-2016, 02:09 AM
tonyb635's Avatar
Originally Posted by Manfrombklyn23@aol.com
Thanks for the advice. BMW was able to read into the computer deeper even though my Indy shop and pep boys were not able to. They found that the low pressure fuel pump went bad. They quoted me $1,900.00, I said no thank you. They charged me $210 for the diagnostics. I got the part from RM European for $260 and my Indy shop will install for $100 bucks!
There are two pumps in there. I recommend that you replace both while its apart. I didn't and after getting it all back together and refueling it the other pump decided it was finished. The process had to be repeated...
Old 06-28-2016, 03:06 AM
Manfrombklyn23@aol.com's Avatar
I just replaced the high pressure fuel pump. Do you mean that there are 2 low pressure pumps in the gas tank?
Old 07-09-2016, 07:56 AM
Hey you were right. I'm having the same exact problem after replacing the fuel pump in the gas tank. What other pump are you talking about? All the diagrams say there's only one pump in my car. Even my parts guy says he can't locate another pump. There's def an issue. The mechanics saying one of the tanks is staying lower than the other.
akaveli3
01-12-2021 08:46 AM
illogic847
08-22-2015 08:12 PM
vikstas
08-14-2015 10:03 AM
tadie410
04-13-2004 02:41 PM
drinkh20
04-02-2004 04:58 AM
Quick Reply: 08 535xi engine malfunction & fuel pump
