08 535i - Restraint System Malfunction
#21
My Ride: 2008 BMW 535i Silver - E60
I guessing the light has to be turned off with a OBD cable and software. A good indy shop should have this. If the problem is not corrected, and the light is cleared, the warring will return. Back in the IBS or somewhere there is a device that will sever the battery cable in case of a roll over. If this system became wet as you described its possible that the dealer is correct and the IBS needs to be replaced.
![Bashwall](https://5series.net/forums/images/smilies/imported/bashwall.gif)
#22
Engine: N54
#23
Awest91
09-17-2022 11:05 PM
daMANiack
07-03-2016 04:06 AM
