07 550I transmission fault after upgrades
#21
My Ride: Silver 07 550I E60 automatic
Engine: v8
I don't have an OEM pan on my car and it's fine.
But it's a very good point that the oil ring may be damaged and sucking air.
If you have a replacement oil ring it would be good to replace it and test
I really thing this issue is something small
I am happy to read that you are trying to fix it
Keep listening to people's suggestions and keep trying
Great people on this site to help when ever they can
#23
Engine: v8
#25
Engine: v8
If the solenoids had anything to do with the tranny pumping fluid while it was in park, I suppose I could put all the old solenoids back in like someone suggested but I just figure they play no rule in getting the tranny fluid in.
Yesterday once again I could pump close to 4 quarts in until a slow drip formed. I started the car letting it idle for 30 seconds and pulled the fill plug to find a steady slow stream coming out now that the car was running. It also through up a trannymalfunction error and dbc warning error saying car could be put into gear without pressing the brake.
I'm not the quiting type but this car is winning the fight. I found a car like mine at a u-pull it salvage yard that will sell me the transmission for 1k, if i can find a qualified bmw mechanic I may go that route if I don't figure the problem soon. Im also starting to worry that now that I tried filling so many times I fear something else may be damaged since no fluid is circulating
#27
Engine: v8
#28
My Ride: E60 2006 sedan auto
I would clean as good as possible with some brake fluid and then try it
The reason I suggested it was because your transmission was working before even though poorly
If we know that everything else is fitted properly then I would check that it's not the pans fault
You have nothing to lose
#30
Engine: v8
