05 545i common issues?
Old Dec 29, 2011 | 04:28 AM
  #21
aharper's Avatar
Originally Posted by 545i05
I love my 05' 545 but I put so much money into repairs I can't decide to keep it or sell it at this point.
I had the same and thought the same... finally traded the car for a loss and felt as good letting the car go as I did when I bought it. Funny how that worked out. I miss the car but don't miss what it cost me.
Old Jan 13, 2014 | 05:59 PM
  #22
dallas535i's Avatar
My Ride: 2006 550i Auto trans, Navigation, Comfort Access, Adaptive Lighting, Dynamic Drive, Sport Package, Logic 7 Audio, Voice Control, Shades, Active Steering, PDC, Heads Up Display, Heated Front Seats, CD changer, Satellite, Extended Lighting Pkg
Originally Posted by aharper
I don't want to talk you out of it, because I really loved my 545i, but I won't buy another one. --SNIP-- The car was a blast to drive, looked great and was tons of fun but very costly. I likened it to an incredibly dysfunctional relationship... for awhile you somehow tell yourself that the problems aren't that big of a deal because you love the car. After awhile it wears on you.
So, true, even with my 06 550i. Thankfully I can do much of my own wrenching, except for the embarrassing smoking exhaust due to bad valve stem seals. I hear these are eventual for the V8, so factor in a couple grand for that eventual repair on top of the list that was typed earlier. Expensive mistresses, V8 BMWs.
Old May 13, 2014 | 09:23 PM
  #23
Cynthia_Bimmer's Avatar
My Ride: BMW M3
Default BMW N62 V8 Coolant Pipe Repair Kit
Hello,
I am writing to tell you about a new BREAKTHROUGH method for repairing a leaking Coolant Transfer Pipe in the BMW N62 V8 engine block using the BimmerFix Stint. The N62 V8 is a popular BMW engine that was used from 2002 thru 2010, in such fabulous vehicles as the BMW 735i, 740i, 745i, 750i & Li, 645Ci, 650i, 540i, 545i, 550i, and the X5 SUV.
Located deep inside of this BMW N62 engine is a Coolant Transfer Pipe, which carries antifreeze from the Water Pump to cooling chambers within the engine. However, the Front Seal on this Cooling Tube can fail in as little as 40,000 miles, and start leaking antifreeze from the engine block, through a weep hole in the Timing Chain Cover. When this happens, the car will lose antifreeze from the engine, and the engine will overheat.
In the past, this has been a very expensive repair because it required disassembly of the engine, in order to access the leaking Cooling Pipe Seal. The original method of replacing the crossover Coolant Transfer Pipe required the removal of the Timing Chain Cover. This repair could cost $6,000 or more at the BMW Dealer.
Then, an after-market Collapsible Coolant Pipe was developed to save time and money on this repair. This Collapsible Coolant Pipe method involves removing the Intake Manifold, cutting out the old Coolant Pipe and installing the after-market Collapsible Coolant Pipe. But even this method required many hours of shop labor and expensive parts and supplies. The repair bill for this method can still cost between $1,500.00 and $2,500.00 to remove the Intake Manifold, cut out the old Coolant Pipe and install the new Collapsible Coolant Pipe.
However, BimmerFix Products Co. has discovered a BREAKTHROUGH system to stop the leak! The BimmerFix method is much faster and less expensive than these old methods. This simple, yet durable and long lasting method inserts the BimmerFix Stint into the leaking crossover cooling tube, through the Timing Chain Cover. The thin aluminum sleeve creates a long lasting repair that is much easier and less expensive to install than the old repair methods.
The new BimmerFix Stint will stop the Coolant Pipe leak, and only requires the removal of the Water Pump. This new patent protected invention can save YOU or your customer’s time, hassle, and thousands of dollars. It works or your money back!
Save time and money! Take a look at Bimmerfix Products Company - Bmw N62 V8 Coolant Transfer Pipe Repair Kit For Bmw 545i 550i 645ci 650i 745i 750i X5 And More By.
Watch The Video! You will be glad you did!
Thanks for your time!
Tucson, Arizona, USA
Old May 15, 2014 | 04:55 AM
  #24
Dremers's Avatar
My Ride: FX35 Supercharged
Purchased my 545i in December with 139k miles and it now has 146k. I have changed the oil and i am about to change the brakes. I did have a leaking thermostat sensor that cost me 220 to fix but that has been it.
We shall see what the next yr brings because i am thinking about upgrading to an e90 M3 or a E60 M5.
Old Feb 22, 2020 | 04:22 PM
  #25
ron_of_orange's Avatar
My Ride: 2004 BMW E60 545i
Engine: N62
I'd be curious to see any forum members who may have confirmed this ...repair since the original posting here. Just curious. thks
DavaiLave
Aug 2, 2022 02:16 AM
BMW565
Nov 6, 2017 06:03 PM
Grrrit
Jun 10, 2015 01:04 PM
hc115
May 12, 2015 06:37 PM
UltimatePeter
DIY: Do It Yourself
May 12, 2015 08:00 AM
