05 530i fan on at startup
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Originally Posted by donpb
I see a dude on YouTube using a MaxiDAS to turn the fan on / off. The control signal is pulse width modulated, so can't measure with a DVM.
You could have an intermittent connection or a wonky fan.
I was just reading how the coolant temperature sensor and also the a/c play a part in it.
If the coolant sensor is disconnected (or faulty or intermittent) the fan will turn on high (uncontrolled).
Model Year: 05 530i
Engine: 3.0 M54
I finally found out why the fan comes on at startup. Apparently since the aux pump was a knock off when the car does it's initial check it triggers the fan. Its just like when you install LED side markers and the car does a check at startup the lights flicker. I exchanged the pump with an OEM one and it stopped.
Model Year: 05 530i
Engine: 3.0 M54
The brand was right but it was a knock off. They looked exactly the same and around the same price. The Amazon seller got me. Lol. I got the money back so no harm no foul.
Quarta2six
01-31-2013 11:28 AM
appartment46
10-22-2009 03:48 PM
