-=Prevention Thread=-
Old 11-11-2009, 05:07 PM
  #21
einstein57's Avatar
My Ride: 05 530i 87 325is 85 VW GTI
Some of those things are overkill like the radiator,02 sensor, exhaust components (unless your referring to bushing) and diff seals. There is a big debate on whether or not to replace the "lifetime" tranny fluid. And there is not timing belt to wory about.
Originally Posted by toddstebleton' post='1035383' date='Oct 18 2009, 06:48 PM
2004 525i
I only have 44K on this vehicle, but here's what I'm planning to replace sometime before 80K.
Spark plugs every 40K (possibly wires), timing belt/water pump/thermostate/belts/idlers, battery, air filter (every 20K), fuel filter (every 40K), oxygen sensors, cabin filters (every 20K, with air filter), check all coolant/radiator hoses. Some control arms will likely be replaced between 40-80K.
Probably replace by 100K
All coolant/radiator hoses, coolant tank, radiator, exhaust components, differential seals, transmission service (filter, new gaskets, seals, fluid), maybe alternator.
I also have an Audi A4, so many of these thoughts are from my experience with that vehicle - fyi. If you have experience something different or if this sounds ridiculous, let me know.
Old 11-11-2009, 07:19 PM
  #22
08white's Avatar
My Ride: 2008 BMW 535XI white
2008 535XI with 6k miles now
battery replaced at 3k miles
thifter replaced under 6k miles (they need to reprogram the whole car after replacement)
AWD and DSC malfunction error when driving on highway after 20-30 minutes
but local is ok, BMW said it is alignment
Old 11-11-2009, 07:26 PM
  #23
Banned
John@Motorcepts's Avatar
My Ride: A Car
Guys, a freakin starter is only $177.46 with an $80 core exchange charge. An alternator is $361.24. O2 sensor is $129.17 before cat and $114.89 after cat. Fuel pump is $245.60. Why are you guys PAYING so much???? Thermostat is $57.92.
www.drivewire.com is your friend! Their prices are fair and you get your parts quick.
Old 11-12-2009, 12:07 AM
  #24
tbal's Avatar
My Ride: See sig :)
Originally Posted by kaiten408' post='935954' date='Jul 7 2009, 11:20 PM
2005 545i
- lower radiator hose replaced due to leak @ ~40K miles
- door seals on driver and passenger replaced @ ~40K (there was major tears in them from previous owner, i just replaced them under warranty)
I think all hoses in the engine bay should be checked regularly and dressed with some protectant to keep them from cracking, etc. along with the door seals
@ V_therussian: What happened to your control arms? I've been getting a slight vibration in my car on highways. I've had it checked out and I know for a fact that two of my wheels have ever-so-slight bends in them, but in the back of my mind I keep thinking about the upper & lower control arms
Any suggestions on good protectants?
Old 11-12-2009, 04:56 AM
  #25
v_therussian's Avatar
Old 11-12-2009, 03:28 PM
  #26
VTGT's Avatar
Subscribe for good information.
Island Road
04-06-2016 12:42 PM
wooboodoo
10-25-2015 02:58 PM
timmay77
09-23-2015 12:34 AM
Gregm
09-17-2015 03:57 AM
benski
F10 Discussion
09-16-2015 07:10 PM
Quick Reply: -=Prevention Thread=-
