Your Opinions, Please!! Re: 2002 530i
I am considering purchase of a 2002 5 Series 530i. Mileage is just under 112,000. It's a one-owner, Southern California car with pristine CarFax. Purchase would be from a BMW dealer that has been servicing the car since 2008.
I'd appreciate your thoughts about this particular model. Are there any recall problems or other mechanical issues I should be aware of? What is a reasonable life-expectancy (in terms of mileage) for this car?
And any other words of wisdom would be welcome!
Many thanks!
Many thanks!
The early 6 cyl 5 series were pretty bullet proof with the usual problem areas:
Good luck with your decision!
- Cooling system - plastic radiator and reserve tank - ensure they have been replaced recently.
- Front suspension - esp control arms and center link - same as above
- Automatic transmissions - should be considered a maintenance and replacement item at 100K miles - if transmission oil and filter were serviced recently and car driven responsibly you may expect to go the distance! If it's a manual it's a fun car to drive!
