E39 Discussion Anything and everything to do with the E39 (1997 - 2003) 5 series!
Headlight adjustment
Old Jan 16, 2023 | 07:52 AM
letterman's Avatar
My Ride: E39 stick with sport package
Default Headlight adjustment
I have a 2001 E39 with a sport package. Standard headlights (no auto-adjust). My headlights have somehow drifted low over time. So much so that I can't see very far in front of me with low beams on and rarely get flashed if I keep high beams on all the time. I have tried adjusting the headlights using the inner hex screws which control the adjuster wheels. While they turn the adjuster wheels, there is no real impact on the light angle. And it's the same issue on both sides. Does anyone have any experience with this? Any suggestions (other than just driving around with high beams on all the time)?
Thanks.
Old Jan 16, 2023 | 08:26 AM
donpb's Avatar
My Ride: '06 530i N52
Old Jan 16, 2023 | 10:49 AM
letterman's Avatar
I need to do some hunting. That video relates to the pre-facelift headlights, which I suspect is different than the facelifted lights I have that came with mine (first year of those, I suspect). Thanks for the lead. Have you seen anything about doing that with the newer ones?
Old Jan 16, 2023 | 03:32 PM
donpb's Avatar
I am almost sure your plastic headlight adjusters became brittle and need replacing. That video was for reference only.
Eurobahn BMW
Jan 16, 2023 03:38 PM
Cristian-Nicolae Goian
Jan 20, 2014 02:33 AM
MarcsOnFire
May 25, 2009 09:14 AM
BMW530
Nov 23, 2006 01:06 PM
525iSE
Nov 19, 2006 05:44 PM
